Old 08-03-2010, 12:26 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
RSS under pulley: can I reuse the crank pulley bolt?
I've been postponing this install due to lazyness. Now it's time. I called rss to see If I could reuse my crank pulley bolt and I didn't really get a confident answer but he said for my year yes I can reuse it. Just wanted to know if anyone has reused it before without issues?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 08-03-2010, 12:30 PM   #2
There was a writeup on here very recently covering this.
IIRC, they are not reusable. The bolt stretches when torqued to spec, similar to many head bolts.
98 Arena Red 986
Old 08-03-2010, 01:08 PM   #3
Carnut
AndyA6's Avatar
How about the belt, then? I guess that has to be changed as well, right?
Old 08-03-2010, 01:53 PM   #4
I have the RSS underpulley, I used the exact same bolt, I have driven the car in a very spirited fashion without any problem, as for the belt, it's a different size, replace the bearings in the rollers too, they are cheap at napa.
Old 08-03-2010, 03:30 PM   #5
bolt replace
I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?
01 boxster black/tan- FVD exhaust and ECU tweak, K & N air filter,
de snorked, underpulley, carbon fiber rear wing, H & R lowering springs, lemans rims by victor equipment
lbrown2009 is offline   Reply With Quote
Old 08-03-2010, 09:47 PM   #6
2001 RUF 3800S
I called Porsche and the part is like only 4 dollars so ill just switch it just incase. But I thought with the RSS UP you can reuse the same belt?
IG: RUF3800S
Old 08-04-2010, 03:08 AM   #7
[QUOTE=lbrown2009]I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?[/QUO
Eggactly, I would only add mine was pristine, zero corrosion or thread corruption.
If anyone wants the roller bearing numbers or the gates belt number message me, I have both in my car log.
