06-27-2010, 05:22 PM
#1
how do you remove rear bumper
I want to polish my exhaust and I can not figure out how to remove the rear bumper. I took the front off yesterday because I found a great writeup and Youtube but I can not find one on the front. Please help
07-16-2010, 06:12 AM
#2
You need to start by removing the rear spoiler first.
-Raise the spoiler manually w/ the switch near the dead pedal(or the rear spoiler switch if you've done that mod)
-Open the rear trunk so you don't mess it up while work
-Get a center punch,small nail or something you can tap the middle of the three rivets out with
-remove the rear spoiler cover
-Remove the two bolts located inside the spoiler by looking downwards within the spoiler
-Lift and remove spoiler
Now removing the rear bumper
-Remove the bumperettes by releasing their bolt. You can see the bolt when you get on the ground and look on your back
-remove the wheel well housing screw, 1/side
-remove the three screws located on the bottom of the bumper, 3/side
-remove the screws from the license plate lighting,2/per light
-release the lights from the bumper
thanks to Blinkwatt
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
07-16-2010, 07:25 PM
#3
+1 on GTA_G20 -- you might even be able to do it faster than it took him
to type it -- nice write up!
Mike
QUOTE=GTA_G20]You need to start by removing the rear spoiler first.
thanks to Blinkwatt[/QUOTE]
07-16-2010, 09:13 PM
#4
its really that easy took me maybe 30minutes and Im enclined but this required zero effort
07-17-2010, 05:50 AM
#5
This should be a sticky, or maybe added to the FAQ if it isn't there already.
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
03-24-2012, 05:11 AM
#6
Just to say thanks for the instructions, they worked a treat!
03-24-2012, 07:54 AM
#7
still plays with cars...
Don't remove license plate lights from rear bumper....
Even my Bentley manual says to remove them! It's a total PITA to reinstall.
Just follow the wiring back to where it plugs in to the body harness and disconnect it there. Just unclip the plug and go.
A lot less messing around, and less chance of breaking something. Just remember to plug the harness together before buttoning up, or you'll get more practice taking the bumper off again to reconnect the wiring!
02-28-2014, 02:01 AM
#8
I've got to swap my damaged rear bumper tomorrow. Does anyone know whether the centre pins to the spoiler rivets are easily recoverable for re-use after being pushed in?
02-28-2014, 05:54 AM
#9
yes
the pins are easy to find. Super easy job! No worries....it's not the space shuttle!
02-28-2014, 09:45 AM
#10
I have an 04 Boxster S, and my rear wing doesn't have the 3 rivets with the push out centers. How is the top of the wing being held on? Does anyone know how to remove it? Thanks.
Tony
Lapis Blue 03 Boxster S
02-28-2014, 03:08 PM
#11
Tony
There are three holes underneath the wing. Use a small screwdriver and insert it into the hole. The clips need to be pushed toward the front of the car very gently. The painted portion will pop off and you can get at the two bolts holding the spoiler.
2004 Boxster S
03-01-2014, 10:54 AM
#12
Bumper swap completed without too much fuss today, obviously it looks much better than the damaged one I removed and I was relieved to find no further damage hiding beneath it. Interesting to see an emergency boot (US=trunk) release cable hiding beneath there as well.
Except for one tiny thing: the wiring loom plug for the number plate lights was crushed. I didn't have another one to hand so managed to effect a temporary solution, but would like to properly replace the damaged plug as it connects neatly to a holder which secures the loom up away from the exhaust.
Does anyone know the part number, please?
Frustratingly, I downloaded a wiring diagram but the plug is shown at the very top of page 209 (third from left) and the .pdf file cuts off the number just above the diagram.
The original plastic rivets holding the top of the spoiler on would have been easy to re-use but I replaced them with new plastic trim rivets which have cross-headed screw pins which can easily be removed. Glad I did as the spoiler needed to be removed a few times for adjustment.
2002 Boxster 2.7 Tiptronic S, Lapis blue, right-hand drive.
03-01-2014, 02:36 PM
#13
Whoa! This thread had 3000+ views already. Guess a lot of people wants to know how to remove the pretty boxster arse!
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
