06-27-2010, 02:37 PM
Is this too hot?
Seams a little higher than it should be.
06-27-2010, 03:17 PM
That's pretty hot for 5:39am?!
Sam
06-27-2010, 03:18 PM
Mine stays there a lot, when it's hot, in stop and go.. it goes to the middle of zero
Sasha
06-27-2010, 03:26 PM
Sam
yeah, I disconnected the battery not too long ago and have not fixed it yet.
06-27-2010, 07:04 PM
There Is No Substitute.
Mine Boxster hangs right around there, and that is with clean radiators and no coolant problems. If it goes significantly past the zero then you should be concerned.
06-27-2010, 08:55 PM
Ok, thanks Rick,
I figured it was good but was not sure. So much to learn about my new toy.
I have such a long list of parts I want. Starting with wheels but I cant figure out which ones I want. I am thinking something in a gun metal color.
06-28-2010, 01:02 AM
Don't worry about the spend on wheels - invest in the the Raby / LN Engineering low temp thermostat, plus replace the coolant - if you do, you won't see temperatures like that again (unless you spend a lot of time in heavy traffic).
I'll wager that the coolant (and oil) temperature(s) are above what you see on the gauge.....
2001 MV Agusta F4.
06-28-2010, 04:10 AM
it's a little higher than my s gets, but nothing too alarming.
06-28-2010, 07:17 AM
hey mb, check out the oz alleggerita rims on tirerack.com; light, gunmetal and (relatively) inexpensive (for the weight).
06-28-2010, 07:21 AM
low temp thermostat and porsche coolent change, Highly recommend redline "water wetter"- 10$. It lowered my max temputure by 15 degrees.
Also if you are going to do the thermo, then I would also put in a new waterpump. It is bound to go out soon if it is original.
I have a scan tool that shows real time water temps. I was getting 225 on a regular basis. Now I only get up to 210 max, usally hangs at 202.
You must remove the bumper and clean the radiators, and move the front radiators to get to the junk inbetween the two.
I bought a radiatior comb for 2$ at auto store to fix the bent vains.
2002 S
06-28-2010, 12:09 PM
Yeah, I did remove the front bumper and clean out the radiators but there was no change. I will try the other things to make sure it helps.
06-28-2010, 12:46 PM
they say lifetime coolent- but if it is original- changeing will not hurt. but keep in mind the coolent is a little expensive, so if you re going to change it, do the thermo, and also give thought to the pump.
if the fans turn on at 212 like they should, then I would just try water wetter.
keep in mind, your temp is more or less normal.
2002 S
06-28-2010, 08:00 PM
Mauiboxster, your reading looks normal. I went out driving today and air temp was around 100 degrees F. My gauge read about the same as your pic, went to the right edge of the zero in traffic. Turned on my AC diagnostics(not sure about accuracy) and coolant temp read 104degrees C (219F) was the highest that I saw.
