Old 06-28-2010, 12:46 PM   #12
jhandy
they say lifetime coolent- but if it is original- changeing will not hurt. but keep in mind the coolent is a little expensive, so if you re going to change it, do the thermo, and also give thought to the pump.
if the fans turn on at 212 like they should, then I would just try water wetter.
keep in mind, your temp is more or less normal.
2002 S
jhandy is offline   Reply With Quote
