Old 06-13-2010, 07:45 PM   #1
A/C not working.. is this common?
Have a 00 S and the a/c does not put out cold air.. So far I have:
Depressed both lines to see if there was any pressure and there seemed to be a ton. I am planning on going by my old work tomorrow and having my boss putting the gauges on it.
Pulled off the access panel to see if the compressor was spinning, which it was. I zipped off the clutch plate and didnt really notice anything unusual.
When I unplug the pressure switch the system stops so it appears to be fine as well.
At this point the only thing I can think of is to check the actual pressure and see if there is a possible blockage???
Has anyone else experienced anything like this? Thanks for looking and the suggestions
Jake D is offline   Reply With Quote
Old 06-14-2010, 02:08 AM   #2
make sure the temp controll is set to cold,feel low side line [next to batt ?] it should be cold. it sounds like low on freon but put gauges on it to be sure...dont over charge
extanker is offline   Reply With Quote
Old 06-14-2010, 05:33 AM   #3
I set the controls on LO, and I have felt both of the lines and neither gets cold. Guess I wont know anything till I put the gauges on it..
Thanks for the response.. Ill keep ya posted
Old 06-20-2010, 07:33 PM   #4
JTP
AC on my 2000 S isn't working either. I measured the system and it shows good pressure, I can hear the compressor kick on when I turn it to Lo. I felt the aluminum lines next to the battery ( on the passenger side) and they aren't cold. I'm not sure which ones are supposed to be cold.
What else should I check? Any helpful suggestions would be appreciated. Thanks.
JTP is offline   Reply With Quote
Old 06-21-2010, 05:07 AM   #5
jcb986's Avatar
What I can remember about AC not blowing cold air is 1) the compressor has gone bad 2) the drier is clogged. These are main 2 problems of an AC, the last one is you are low on freon.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 06-21-2010, 06:36 AM   #6
Franco's Avatar
Hi,
Verify the A/C relay on the panel in the trunk, there is a wired spool in the relay that is connected to some sort of resistor, the wire can snap and cause the A/C not to start.
If that is your situation you can unwind the wire and resolder it to the resistor.
This happened to my car 3 years ago and never failed again after I fixed it .
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
Old 07-19-2010, 06:20 AM   #7
texomawaves's Avatar
Is the AC relay in the front or rear trunk? I'm armed with a voltmeter and soldering iron Thanks!
Chris Dennis, Plano, Texas
'07 Boxster, arctic silver, Tiptronic, 106k miles, no mods
‘13 Boxster S, black on black, PDK, 27k miles, garage queen
‘66 Mooney M20E, hangar queen
texomawaves is offline   Reply With Quote
Old 07-19-2010, 06:28 AM   #8
Opposed to Subie Burble
Overdrive's Avatar
My '97's A/C hasn't been working from the start (a large oversight on my part...I have my moments ), but it's still under warranty from the seller, so I'm going to have them check it out for me. I hear it kick over and run but I get no sort of cold air from it. Hopefully it's just bone dry of freon and a charge will fix everything.
Let us know how it turns out.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-19-2010, 07:19 AM   #9
deliriousga's Avatar
I have a relay chart for the 2000 Boxster on my website at http://www.theschillings.com/pcars.htm Click on the Boxster site then look under "Where Is It".
1966 Wife White/Brown Top
