Old 06-13-2010, 07:45 PM   #1
A/C not working.. is this common?
Have a 00 S and the a/c does not put out cold air.. So far I have:
Depressed both lines to see if there was any pressure and there seemed to be a ton. I am planning on going by my old work tomorrow and having my boss putting the gauges on it.
Pulled off the access panel to see if the compressor was spinning, which it was. I zipped off the clutch plate and didnt really notice anything unusual.
When I unplug the pressure switch the system stops so it appears to be fine as well.
At this point the only thing I can think of is to check the actual pressure and see if there is a possible blockage???
Has anyone else experienced anything like this? Thanks for looking and the suggestions
Jake D is offline   Reply With Quote
Old 06-14-2010, 02:08 AM   #2
make sure the temp controll is set to cold,feel low side line [next to batt ?] it should be cold. it sounds like low on freon but put gauges on it to be sure...dont over charge
extanker is offline   Reply With Quote
Old 06-14-2010, 05:33 AM   #3
I set the controls on LO, and I have felt both of the lines and neither gets cold. Guess I wont know anything till I put the gauges on it..
Thanks for the response.. Ill keep ya posted
Old 06-20-2010, 07:33 PM   #4
JTP
AC on my 2000 S isn't working either. I measured the system and it shows good pressure, I can hear the compressor kick on when I turn it to Lo. I felt the aluminum lines next to the battery ( on the passenger side) and they aren't cold. I'm not sure which ones are supposed to be cold.
What else should I check? Any helpful suggestions would be appreciated. Thanks.
JTP is offline   Reply With Quote
Old 06-21-2010, 05:07 AM   #5
jcb986's Avatar
What I can remember about AC not blowing cold air is 1) the compressor has gone bad 2) the drier is clogged. These are main 2 problems of an AC, the last one is you are low on freon.
Old Hippie Young Heart
Old 06-21-2010, 06:36 AM   #6
Franco's Avatar
Verify the A/C relay on the panel in the trunk, there is a wired spool in the relay that is connected to some sort of resistor, the wire can snap and cause the A/C not to start.
If that is your situation you can unwind the wire and resolder it to the resistor.
This happened to my car 3 years ago and never failed again after I fixed it .
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
Franco is offline   Reply With Quote
