Old 04-15-2010, 06:37 PM   #1
"loose change" rattle, I need an explanation
I have this annoying "loose change" rattle in my car.
I found a post on 986faq that explains a possible solution
http://www.986faq.com/10-0/problems.asp#017
Prblem is I cannot find "the bolt on top of the ball joint", I spent almost an hour looking for it.. and I must be doing something wrong.
Can someone please explain me what to look for? A picture maybe?
Sasha
sasha055 is offline   Reply With Quote
Old 04-16-2010, 05:49 AM   #2
check this thread too:
Ticking noise coming from right behind my left shoulder
Or quite simply, it could be loose change (stuck in your center console) if you or previous owner kept/keep change in your ashtray. The Boxster cabin is small so it's hard to always accurately tell where sounds are truly originating. with the car off, try rapping moderately on the side of the center console. If you hear the loose change sound then, you most likely have some coinage stuck in there. Search for center console removal or short shifter install on how to take out/raise the center console to dislodge.
Good luck
Old 04-16-2010, 05:31 PM   #3
Originally Posted by sasha055
Sasha
It might be something else.
Check the bolts that hold the muffler to the back of the transmission.
Mine are broken off on my '98, and they make a loose change type of jingle at low rpms when taking off from a stop.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
Old 04-17-2010, 03:55 AM   #4
I have determined my loose change noise is the DS push arm for the convertible top. I only hear the rattle with the top up and felling under the convertible mechanism, I feel a loose bracket. Hoping today to get a better look. I will be taking picture as I get to the problem.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
