Old 04-14-2010, 09:54 AM   #1
Clean Alluminium tape in wheel
Hi, I just removed the wheel of my new (to me) boxsterS2006, there is a bunch of old aluminum tape inside the wheel. (used to fix weight to balance the weel I guess). Anyone have a good suggestion about how to clean that up without scratching the wheel?
My guess is with a plastic screeper and a heat gun but maybe some have a better idea to save my time and energy..
vipola is offline   Reply With Quote
Old 04-14-2010, 10:50 AM   #2
vipola,
I used a product called "Goof Off" (www.goof-off.com). I imagine that it is available internationally. It softend the adhesive enough to scrape/rub it off with a phenolic scraper.
Phenolic is a material that used to be used to make old circuit boards. I got the scraper from www.aircraft-tool.com. It took a LOT of scraping and rubbing. You must be careful to scrape only with the flat of the scraper, the corner could scratch the wheel. I hope this helps.
Mark
1997 Boxster
desnorkled
muffler not stock
19" Rims (for show/bad weather)
17" w/Toyo R888's (for zooming)
MarkOfZero is offline   Reply With Quote
Old 04-14-2010, 10:51 AM   #3
Goo gone maybe? Not sure if it's safe for painted surfaces. WD-40 works good for tree sap on cars, so that might be another option.
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 04-15-2010, 02:34 AM   #4
Try using regular corn oil. I've used it to remove various sap and glues. Or use aceton... finger nail polish remover.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 04-15-2010, 04:12 AM   #5
WD-40 will do it!!
1997 Boxster 986
TechArt Championship Formula OZ Wheels,
TechArt Springs
TechArt Strut Brace Front and Rear
Technobrace (Thanks Pedro)
Michelin PS2
G2 Red Caliper Paint
DamageINC123 is offline   Reply With Quote
Old 04-15-2010, 06:52 AM   #6
WD-40 rules!!
(It's also effective against attacking hornets (although I have not tried it against Killer Bees!))
TRawls is offline   Reply With Quote
Old 04-15-2010, 06:59 AM   #7
jcb986's Avatar
I use lacquer thinner....
Old Hippie Young Heart
Old 04-15-2010, 09:59 AM   #8
Allen K. Littlefield's Avatar
I have had good results with Bug & Tar remover. Dissolves the adhesive and you just rub it off with a rag, no scratches. Then clean with a good detergent such as dish detergent that dissolves oil and grease.
AKL
