Old 04-14-2010, 10:50 AM   #2
MarkOfZero
vipola,
I used a product called "Goof Off" (www.goof-off.com). I imagine that it is available internationally. It softend the adhesive enough to scrape/rub it off with a phenolic scraper.
Phenolic is a material that used to be used to make old circuit boards. I got the scraper from www.aircraft-tool.com. It took a LOT of scraping and rubbing. You must be careful to scrape only with the flat of the scraper, the corner could scratch the wheel. I hope this helps.
Mark
1997 Boxster
desnorkled
muffler not stock
19" Rims (for show/bad weather)
17" w/Toyo R888's (for zooming)
MarkOfZero is offline   Reply With Quote
