Old 03-23-2010, 05:42 AM   #1
Conecting aftermarket amp question.
Hi Guys,
I am planning to add an aftermarket amplifier to the stock door speakers in my 99 Box. I have the M490 amplifier now an am trying to figure out if I can connect to the door speaker wires without cutting. I have an idea to cut apart an M490 to use the connector and make a harness. Is there an easier way? I would rather not cut the factory harness to preserve some resale….
chubert is offline   Reply With Quote
Old 03-28-2010, 09:17 PM   #2
I made two adapters so I can use an aftermarket amp with the factory harnesses. The adapters basically plug in where the factory Haes amp would plug in.
Amplifier harness adapters
I used a donor Haes amp to make my adapters. I think I paid less than $20 for the donor Haes amp on ebay. Either making an adapter, or just running new wires, is so much better than cutting the factory harness, IMHO.
dalvarado is offline   Reply With Quote
Old 03-29-2010, 08:36 AM   #3
Thanks, I saw your post before. I located a donor amp so I will be doing the same thing.
I really just need the door speaker wires. It sure loosks like a PIA to fish new wires through the door harneses. I'll just run new ones to the dash since it's pretty easy.
