Old 03-16-2010, 04:57 PM   #1
SDBxstr's Avatar
replacing turn signal switch
i need to replace my turn signal switch i have the 3 stalk switch my question is can i purchase the 2 stalk switch and replace just what i need? if so is there a diy that someone could send me.
thanks
SDBxstr is offline   Reply With Quote
Old 03-16-2010, 05:03 PM   #2
Lil bastard's Avatar
No, it is an assembly, the only stalk which separates from the assembly is the OBC stalk... and even that is not sold separately.
You can replace it with a two stalk, but then you lose the Cruise Control.
Suck it up and buy new from the dealer, sunset, etc., or get a used one from salvage.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-16-2010, 05:06 PM   #3
I just went through this with a used 3 stalk from this awesome site. My TS's quit canceling, and hi beam disappeared. Found a broken plastic piece in the surround German bakelite???
Pretty easy, with these instructions:
http://www.whiteson.org/boxster/mods/obc/obc.stalk.pdf
navair is offline   Reply With Quote
Old 03-17-2010, 04:29 PM   #4
If your lights stopped cancelling, it may not be the stalk, but the clockspring.
Checkout my thread when I had the problem:
Steering column & turn signal help
If the piece you found looks like the larger piece in my first photo attachment, then your clockspring is broken.
-james
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
yimmy149 is offline   Reply With Quote
Old 03-17-2010, 10:05 PM   #5
SDBxstr's Avatar
thanks for the info iwill buy new 3 stalk switch from sunset and install with help from pictures you sent
Old 03-18-2010, 02:14 PM   #6
Unless the Porsche is your daily driver, I wouldn't order the new stalks until you've opened things up. I didn't need new stalks in the end, but still installed the new one because I wanted to wire up the OBC. Might save yourself $200.
-james
