03-04-2010, 10:14 AM
#1
OBC temp sensor Retrofit
Is it possible to retrofit the temp sensor into the P-side front grill of early '97's (i.e., was the rest of the wiring already installed in ALL Boxsters)?
This would be on a '97 that originally came without the temp sensor.
Regards, Maurice.
03-04-2010, 11:10 AM
#2
Yes, it's possible. You need to locate the temo sensor wiring connector behind the bumper and of course buy the sensor and the grill (which has a special 'O' holder for the sensor to snap into. Then just get someone with a durametric, PIWIS or PST2 to initialize the OBC.
Cheers!
03-04-2010, 11:17 AM
#3
Not to knock LB's answer, but I've got a 97 and did a bunch of research on this when I first bought my car.
My 97 does not have the temp sensor plug behind the bumper into which to plug a sensor.
The certified porsche tech that works on my car told me that without it, running a wire and finding the right place to solder it would be a sizable undertaking that wasn't worth the time, labor, and money. He recommended I look on my iPhone for the current outside temp!
I did not like his answer, and would still like to do this mod if anyone can provide clear instructions as to how to add the temp sensor to a car without the wiring or plug for it.
03-04-2010, 11:20 AM
#4
Cheers!
Thanks!
I'll look for that wiring as soon as the weather warms up and I hope it's actually there. Good opportunity to clean out the radiators again.
Regards, Maurice.
03-04-2010, 12:01 PM
#5
Randall,
According to Factory Repair Manual, '97 ONLY wiring diagram - Sheet 3, there is indeed wiring to the P-side fender well for the outside temperature sensor - the connector will be obvious and it is fed by a Brown/Blue wire and a Brown/Orange one. This is for the M659 OBC option which I believe is in all US Market cars.
I can send you the diagram if you wish.
Cheers!
03-04-2010, 12:06 PM
#6
Randall,
Cheers!
Thanks for the specification of the wire colors. That will make it much easier to determine whether they are there.
I have a factory manual, so I will look at Sheet 3 as well.
Thanks again.
Regards, Maurice.
| Thread Tools |
| Display Modes |
Linear Mode
