Old 02-28-2010, 03:55 PM   #1
Best exhaust system for 987
Any suggestions. I have a regular boxster not an S. I want a nice deep sounding exhaust tone.
heatfan5 is offline   Reply With Quote
Old 02-28-2010, 03:58 PM   #2
This topic's been beaten to death. The forum search feature is your friend.
gschotland is offline   Reply With Quote
Old 02-28-2010, 05:38 PM   #3
husker boxster's Avatar
Porsche Sport Exhaust (PSE) has an all-around great sound.
1989 928 S4 5 spd - black
Old 02-28-2010, 06:07 PM   #4
Stock.
Joe
graphicjoe is offline   Reply With Quote
Old 03-01-2010, 02:44 AM   #5
I don't see anything wrong with making these cars louder, they're Porsche sports cars, they are not meant to whisper. However, I would suggest making a internal decision as to how much louder a car you would like, the differences among these muffler systems can be profound. I am adding headers this weekend, they were very cheap so how the sound will be is ??? Whatever you do, keep the stock pipes, if my car sounds obnoxious and ****************ty this year, I'll crawl back under and put the restrictive stock manifold back on, NBD...
eightsandaces is offline   Reply With Quote
Old 03-01-2010, 05:50 AM   #6
I vote none. Straight pipes ftw.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 03-01-2010, 06:22 AM   #7
I just heard a boxster at an autocross and it sounded mean as hell with according to the owner 99$ chinese headers and midas straight pipes.
Old 03-01-2010, 02:35 PM   #8
Take my advise, soak the bolts till your sick of crawling under and then keep doing it anyway. I was 10/12 breaking the same two on each side, which leads me to believe they are the hottest. These bolts seemed extra wimpy, then again steel & aluminum is always tough. Tomorrow should be fun, web tutorials, easy out extractors, faith and luck.. If anyone considers them self the sultan of extraction, I'd love to have your input..
Old 03-01-2010, 04:27 PM   #9
Quickurt's Avatar
If they broke with heads on them, what makes you think an easy out is going to get them out? The best luck we had in machine shops is left hand drill bits. Most industrial supply houses will stock them. Be EXTREMELY careful center punching the bolts before drilling. Some poeple have had good luck using soldering guns to heat the bolt after drilling it. If you get it good and hot and then let it cool, it will crush itself inside the more solid metal, if you get the walls of the bolt drilled out thin enough.
Good luck.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
Old 03-01-2010, 04:39 PM   #10
Good luck.
Kurt,
"If the heads broke off what makes me think an extractor will work?"
Frankly, what other choices are there? Also, a good mechanic friend told me it's how to do it as well as another trusted source. Am I taking the job lightly? Hardly, I purchased all new drills, I'm studying as much information as I can find and then I'll execute the best I can. Besides, with material removed from the center of the bolt, it will eventually yield. Seems hitting dead center is key, I plan on using a graduated approach, punch mark, small bore hole, larger bore but not big enough to be near the threads. I also have mapp gas for heat and a metric tap and die should it come to that. I'm not intimidated by the job, yet I have a healthy respect for the fact that it's a more difficult endeavor than it first appears.
Old 03-03-2010, 08:11 AM   #11
If the threads get totally buggered, you could still install Heli-coils.
Old 03-03-2010, 09:54 AM   #12
Haha see other thread, god I don't mean to sound like Ned Negative but to be effed over by fasteners is the most vexing irritant known to man. There is a lot of pressure on a manifold, hope the helio holds. Thing is the lower splined nuts on the cat convertor are the ones causing major problems at the moment. First time ever using mapp gas, not impressed one bit..
Old 03-03-2010, 12:53 PM   #13
As long as their installed properly, and there's enough "meat" to drill the hole over-size, thread inserts will be stronger than the original Aluminum threads.
Old 03-04-2010, 05:05 PM   #14
http://www.fdmotorsports.net/index_files/Page441.htm
swrd911 is offline   Reply With Quote
Old 03-04-2010, 09:49 PM   #15
Johnny Danger's Avatar
Along with its close cousin the Cayman, there are a vast number of exhaust systems for the 987 being produced. Unfortunately, most of the highly regarded "tuners" have departed the 986 platform, and have shifted their focus mainly on the 987. It may be worth your while to check out the Planet-9.com website. There you will find an almost limitless number of posts on the topic.
