Old 02-08-2010, 10:36 AM   #1
235/40/18
Are any of guys running this size on a 986 with a 7.5" front rim? I'm thinking about going a size wider up front to help reduce the low speed understeer the car has. If so, how is it working for you? Any problems getting them to fit on the rim?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 02-08-2010, 10:45 AM   #2
Quickurt's Avatar
I think tirerack lists the rim width range acceptable for the tire. If not, maybe the manufacturer will have the info.
It may have a clearance issue, but this would also change with different tires of the same technical size.
I went the other way, I have 8.5" wide front rims for that size tire (stock 987 front) and 10" wide rear with stock tire that was on 9" stock rim.
The reason I did this is tire stability. The wider rim restricts the sideall from flexing as much. The narrower rim will probably give more sidewall flex which, depending on individual tire, may increase understeer by distorting the tread or lifting part of the footprint.
Let's hope someone who has tried it sees this thread and responds!
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
Old 02-08-2010, 11:16 AM   #3
ChrisZang's Avatar
I have the OEM 18" rims and am running 235/40/18 on front.
Fits fine and takes a little understeer out
Old 02-08-2010, 11:24 AM   #4
Tire Rack has the range as 8-9.5 for a 235/40/18 but I'm not going to let that dissuade me yet. I know of some fellow Mazda autocross guys running a 245 on a 6.5" rim!
good good. Thanks Chris!
Old 02-08-2010, 01:24 PM   #5
ChrisZang's Avatar
Actually when I ordered the size on tirerack I got a call from them on my mobile phone the next day, verifying that I really wanted that size. I then confirmed (and convinced them) and then they shipped it.
Pretty good customer service, ey?
Old 02-08-2010, 01:45 PM   #6
That is good customer service. I have had nothing but great experiences with Tire Rack which is why I keep going back.
Old 02-08-2010, 01:54 PM   #7
jcb986's Avatar
I run 225/40/18 on the fronts and 265/35/18 on the backs. Just what you see here. Nice feel and handling...I do not performance drive at all...to old for that anymore.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
