Old 06-25-2010, 03:58 PM   #21
^Yes. The clutch and brake system feed off the same fluid reservoir in our boxster.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 06-25-2010, 04:32 PM   #22
Porscheectomy
They share the same reservior but if the dealer didn't bleed the brake calipers, your brakes weren't serviced. Although it's hard to believe they wouldn't do the brakes.
Old 06-25-2010, 05:37 PM   #23
Yes, your clutch and brakes use the same fluid. When you change the brake fluid, bleed the clutch as well.
*Edit* Oops. Looks like I should have clicked the "Page 2" link before adding my repetitive reply.
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 06-25-2010, 06:25 PM   #24
Originally Posted by Samson
You can also get a one-man bleeder kit for under $10. I've used mine on several cars, and it works great.
Samson, where do I get a bleeder kit for 10$?
Sasha
sasha055 is offline   Reply With Quote
Old 06-26-2010, 10:58 AM   #25
most autoparts stores (PepBoys, Autozone, AdvandedAuto etc) carry them. You could evn make your own with some tubing and a jar.
kabel
Old 07-10-2016, 10:16 AM   #26
LEJ
Harbor Freight has them for $5.99
LEJ is offline   Reply With Quote
Old 07-11-2016, 05:14 AM   #27
mikesz's Avatar
I have a 99 and had the water logged booster issue. So while I was at it replacing the booster and retro kit to NOT get water logged again, I replaced the master cylinder and so had to drain the complete system. While I was at it I replaced the bleeder valves with speed bleeders from Pelican, painted my calipers, and replaced the rotors with drilled ones. I think its cheap insurance and the pedal feel is much improved.
99 Porsche Boxster
Old 07-11-2016, 05:44 AM   #28
I am my own mechanic....
Timco's Avatar
Last time I used my motive bleeder, I heard a hissing noise. The tubing had a pin hole leak from age and was spraying brake fluid (very fortunately) away from the car. Watch that surgical tubing hose!!
'08 VW Touareg T-3 wife's car
Old 07-11-2016, 08:10 AM   #29
I think most of us treat various cars differently for this topic. My Porsches yes I do flush every few years but my daily drivers are treated differently.
My Lexus sedan which I've owned since new (2001) now has 117k and my minivan which I use for long trips now has 140k (2003) both have original fluid. Yes I'm getting around to doing them but I don't treat them like my Porsches. I've owned other cars that I drive towards 200k miles and never flushed the fluids and never had a problem.
General maintenance I do them routinely but my parts are from your local autozone or Pep Boys for my daily drivers. My Porsches I tend to use OEM or Pelican or other reputable Porsche parts suppliers.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
