Old 01-18-2010, 09:45 PM   #1
'98 Boxster ignition sw./starter issues
My '98 Boxster is having starting problems - turn the key, accessories come on but starter won't engage. Pull the key, try again, repeat a few times and finally it will start.
It has been doing this from time to time in the past, but usually pulling the key, turning it over and trying again fixed the problem. Starting yesterday, though, it's doing it every time and takes more and more attempts to start.
I have now noticed, however, that depressing the clutch a couple of times before trying again helps.
Ignition switch assembly was replaced by Porsche dealership 1 yr ago.
Any ideas what might be the cause of this issue, anyone?
Bravosierratango is offline   Reply With Quote
Old 01-19-2010, 02:56 AM   #2
You say that depressing the clutch a couple times help. Sounds like the micro switch on the clutch. Not sure where it is, but it wouldn't allow you to start without seeing the clutch pressed.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 01-19-2010, 03:50 AM   #3
If you lay on your back under the pedals and look at the pedal arms you will see small plastic, plunger actuated, micro-switches. If the switch plunger is sticking or not extending that could be the issue. If you carefully remove the switch it's somewhat adjustable, you might try a tiny amount of lube first or if you confirm it's the switch then just replace it. It's an inexpensive part and other than the body position an easy repair.
eightsandaces is offline   Reply With Quote
Old 01-19-2010, 05:36 AM   #4
in a pinch, you can bypass the clutch micro-switch by shorting it using a jump wire between the connectors on the rear. Just make sure you still have the clutch engaged or the car in neutral when you go to start it.
Old 01-19-2010, 06:28 AM   #5
ppbon's Avatar
In a pinch?
That's been one of my permanent hacks since I bought the car.
It's very useful when tinkering, to just reach in through the open window and start her up.
Also, when I live in MO, in the winter, when it was below zero, I'd start the car without having to sit on the cold, cold seats.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 01-19-2010, 09:13 AM   #6
A pinch for those who have not already done the permanent hack
Heard your 'long' winter is now over. Must have been tough to keep the top up for a few days in January :ah:
Old 01-19-2010, 10:53 AM   #7
Pinches & hacks
Thanks everyone for the intel! I appreciate the help and will get to work asap.
Old 06-13-2021, 09:37 AM   #8
I know this is kind of an old post but just trying. I have the same exact issue (have to turn the ignition key multiple times to start). Not a battery problem. It does not even crank. The frequency is now increasing. How did you resolve your issue? Do remember? Thanks much.
Sam7768 is offline   Reply With Quote
Old 06-13-2021, 03:44 PM   #9
replace the switch, very common problem
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
