Old 01-19-2010, 05:36 AM   #4
Burg Boxster
in a pinch, you can bypass the clutch micro-switch by shorting it using a jump wire between the connectors on the rear. Just make sure you still have the clutch engaged or the car in neutral when you go to start it.
