Old 02-10-2010, 02:56 PM   #21
I had/have the same problem. If you tap on the switch mechanism is usually comes on. I took it all apart and tried to lube the switch itself with limited success. Only the Germans could come up with a switch design that is as complex as this one. The design is virtually guaranteed to hang up eventually.
I did discover a quick way to check the bulb. If you open the rear trunk, it should light up both the front and rear bulbs.
BTW, how much did you pay for the front latch switch mechanism?
gsrhoden is offline   Reply With Quote
Old 02-10-2010, 03:19 PM   #22
KevinH1990's Avatar
Originally Posted by jim_hoyland
Thanks for the tips and info. I found a DIY on Renntech, ordered a replacement microswitch, from Suncoast and did the exchange. The front trunk light is back.
One question though: There are two cables entering the front trunk latch, one from the right-driver side-, and one lower from the left ( pass side ). The upper one from the right looks like its attached to the manual mechanism on the door sill.
What is the lowere cable about ??? Curious minds want to know
I just changed my switch too. Nice to have the light. In my case it has been two years.
I thought that the extra cable was for the emergency trunk release. It is needed to open the trunk if the battery dies. I didn't explore further, but it appeared to lead in that direction.
Old 02-10-2010, 03:38 PM   #23
KevinH1990's Avatar
$47.63 from Suncoast, plus about $7 shipping
I think the switch has been redesigned. I hope the problem doesn't recur.
Old 02-10-2010, 05:32 PM   #24
jim_hoyland's Avatar
I thought the front latch opener in the drivers door sill was mechanical--and I'm assuming it leads to the upper cable on the front latch.
It's this second lower cable I'm confused about--emergengy release ? Where's it leading to ?
jim_hoyland is offline   Reply With Quote
Old 02-10-2010, 06:06 PM   #25
Porsche "Purist"
Paul's Avatar
Glad to help, the lower cable is the emergency release, the other end is usually tucked in the passenger wheel well underneath the inner fender liner.
1987 924S. 2002 996TT. PST-2
Old 02-10-2010, 06:24 PM   #26
KevinH1990's Avatar
Here's a more complete explanation:
http://sites.google.com/site/mikefocke2/whenyourbatteryisdead
Old 02-11-2010, 02:19 PM   #27
Here's the link to the renntech DIY article. It's pretty straightforward.
http://www.renntech.org/forums/index.php?showtopic=20789&st=0&gopid=168044&#entry168044
Old 11-02-2010, 01:29 PM   #28
Front Trunk Light Staying On?
My girlfriend's '99 Boxster's battery was constantly draining over a 2-3 days period. I discovered the front trunk light was on all the time. I took out the bulb today to see if battery would hold charge. The battery was tested twice by the way, and was judged good. It's an Optima.
I was thinking someone may have slammed the trunk lid and damaged the switch. Possible?
Thanks.
ronev is offline   Reply With Quote
Old 11-02-2010, 04:24 PM   #29
Porsche "Purist"
Paul's Avatar
Does your horn beep when you lock the car?
Old 11-03-2010, 08:15 AM   #30
Yes, always has....and the battery would not start the car this AM.
Old 11-03-2010, 08:44 AM   #31
Porsche "Purist"
Paul's Avatar
It should not beep, so yes your latch is likely bad.
Old 11-03-2010, 08:49 AM   #32
Update: The front trunk lamp switch does work, and closing the trunk lid does turn off the light. I took off the latch from the lid and shoved it in the latch hole.
The battery is on a charger now, and hopefully it will charge the battery with the trunk light on.
Old 11-03-2010, 08:59 AM   #33
Wow, she's owned the car for 3 years and it's always beeped once when locked with the remote. You're saying there's been a problem for 3 years?
Old 11-03-2010, 09:04 AM   #34
Porsche "Purist"
Paul's Avatar
Wink
Yes the beep usually means the alarm system thinks something is not closed.
Old 11-03-2010, 09:09 AM   #35
Ok, thanks, Paul.
Old 11-03-2010, 10:31 AM   #36
Can you tell me what was the price of the microswitch part for the front trunk latch?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
