Old 12-15-2009, 04:12 PM   #1
Car stopped running...need a thought
My car ran ok till last week when it stalled. It would only stall @ a stop light w/the a/c on. Then it stalled w/o any accessories on & took a couple min of sitting & it started again. Today it did the same thing, couple min later it started, but ran w/a miss & eventually stalled again. Not it will start, but only for a couple seconds & then dies out. Only code showing is P0102...thing is I just put a new MAF in a few months ago. Could this be a MAF issue or maybe a fuel pump or filter issue, b/c it seems to being starved of fuel & that leads me to think it could be a bad fuel pump or clogged fuel filter.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 12-15-2009, 05:40 PM   #2
Porsche "Purist"
Paul's Avatar
What year and has any work been done on the car recently?
1987 924S. 2002 996TT. PST-2
Old 12-15-2009, 05:54 PM   #3
Its a '98 w/65k and no work other than a mass air sensor about 6 months or so ago.
Old 12-15-2009, 06:13 PM   #4
Porsche "Purist"
Paul's Avatar
When trying to start, is the starter turning the motor?
Old 12-15-2009, 07:03 PM   #5
yes. it actually starts, but it just stalls out within 10-15 seconds no matter what I do to keep it running.
Old 12-15-2009, 07:08 PM   #6
Porsche "Purist"
Paul's Avatar
When it shuts down, does the tach slowly return to zero as the motor slows and stops, or does it fall to zero like a rock?
Old 12-16-2009, 04:13 AM   #7
Slowly as best I can recall.
Old 12-16-2009, 10:02 AM   #8
jcb986's Avatar
Oxygen Sensor
Never had a problem on mine but my 04 Trailblazer did. Started running rough, die, hardly go. Turned to be a oxygen sensor. I believe it was upstream. :ah:
Old 12-16-2009, 02:47 PM   #9
Porsche "Purist"
Paul's Avatar
If it drops in proportion to the engine revs, it is probably not an electrical issue.
I'd check the fuel pressure first.
Old 12-16-2009, 05:25 PM   #10
jcb986's Avatar
Just remembered
I had an issue with a Toyota one time, ran good but when you got going it seemed to run out of gas. Stopped and waited about 5-10 minutes, started up and would run fine and as soon as you got, say 50mph it would do it again. I had a friend that had worked at a Chevy dealership and he came with the idea that there was something in the gas line. We disconnected it from the tank and fuel pump. Took a higher pressure air hose to the line and a piece of plastic came out. After that never had another problem. :dance:
Old 12-16-2009, 07:18 PM   #11
Well, for what it is worth, for anybody who has a future issue like this, it appears to be a bad throttle idle air valve.
