Old 10-17-2009, 05:02 PM   #1
pinging/rattling sound at 3100rpm
03 Boxster S is getting a sound that I would describe as rattling or maybe pinging coming from the engine at almost exactly 3100rpm. +/- 100 rpm and it runs perfectly smoothly. This has been happening for more than a month now. It is fairly loud. Any ideas what this could be?
boxster1 is offline   Reply With Quote
Old 10-17-2009, 06:58 PM   #2
Mine does that exactly as you describe. I think I recall something about vario-cam action at that speed. I do know that mine has made this sound since the day I got it and no ill effects.
Kurt Weber
http://home.comcast.net/~kwinaz/porsche/DSC_0005_1.jpg
2004 986S
Tucson, AZ
Kurt W is offline   Reply With Quote
Old 10-17-2009, 08:31 PM   #3
i get some chatter at startup sounding similar to what you describe and im not sure the car gets quite up to 3k when i start her but... idk hopefull someone shed some light for ya
Old 10-17-2009, 09:31 PM   #4
Engine size?
clickman is online now   Reply With Quote
Old 10-17-2009, 10:47 PM   #5
well i ahve a 2001 2.7 and teh OP im guessing has 3.2 since its a 03 S
Old 10-18-2009, 01:14 AM   #6
yes, it's a 3.2
Old 10-18-2009, 05:04 AM   #7
Porscheectomy
It's most likely to be the engine mount.
Old 10-18-2009, 01:33 PM   #8
I would have said motor mount too, but for that it's described as pinging/rattling, when I thought motor mount created vibration. I've got the 2.7 and occasionally, not always, get the seat-of-the-pants vibration at around 3100-3200. I'm at 50k miles, so in theory I'm due for the motor mount.
Old 10-18-2009, 02:42 PM   #9
Porscheectomy
Symptoms depend on how worn the mount is.
Old 10-20-2009, 10:05 AM   #10
I don't feel any vibration. I only hear the sound and it is fairly loud.
Old 10-21-2009, 07:41 AM   #11
Could be a number of things. My 2000 S has exhaust resonance at the same rpm, but then I am running no cats and 2" pipe from the after-market headers to the muffler so it is to be expected.
The first thing I would look at is the exhaust. Maybe a part of it is touching the body of the car??
I would not think it is an engine mount, I replaced mine last week and am familiar with symptoms, but I could be wrong.
Good luck with your diagnostics.
Daniel R is offline   Reply With Quote
Old 10-21-2009, 03:24 PM   #12
3000ish RPM is where our exhaust hits resonant frequency. If you have a loose heat shield or a catalytic converter that is starting to degrade, that's the RPM where you'll hear it rattling/pinging.
If you post up a sound clip, you might get some better guesses. Good luck!
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 05-16-2010, 01:21 PM   #13
I have a 2001 boxster with 100,000 miles on it. I hear a rattling from the catalytic converter, I know, because I used a stethoscope to detect where the sound was coming from. Might be an oxygen sensor cap.
dm1270 is offline   Reply With Quote
Old 05-16-2010, 04:47 PM   #14
Send a message via MSN to Matt Fredrikson
Might sound odd but I had a similar problem and it turned out to be the steel clip the sandwiches on the center of the under body paneling. Didn't have a nut on it so it was just rattling around in there right at 3000 rpm as well, worth taking a look! Just reach under the car with a flashlight or whatever and wack the under panneling and you'll know right away.
Matt Fredrikson is offline   Reply With Quote
Old 05-16-2010, 10:16 PM   #15
I have a 2.7 2005 same problem
Took it to the dealership numerous times , mechanics on both LA Auto Gallery and Pacific Porsche told me it's nothing to worry about, it's just the fuel injectors. 5 yrs later no problem so far.
speedyellow is offline   Reply With Quote
Old 05-17-2010, 01:00 PM   #16
Bobiam's Avatar
If the car has more than 50-60K on it and you plan on having it next year, you might as well do the engine mount now. First there is a good chance that some minor vibration is causing an exhaust rattle. The 3000rpm area is exactly where the problem is most often noticed. And if that wasn't it, you will likely need one by next year anyway. It should be part of the maint schedule at 60K.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
