Old 10-09-2009, 07:42 AM   #1
Passenger Window not going under convertible top?
80% of the time when someone gets of out the passenger seat the window doesn't go up or down under the convertible automatically like the drivers side does and it sounds bad! I have to put it down and up manually. Anyone know the cause of this?!
BoxsterLewis is offline   Reply With Quote
Old 10-11-2009, 12:26 PM   #2
you might have a faulty door latch sensor or loose connection
dirtyg is offline   Reply With Quote
Old 10-14-2009, 09:13 AM   #3
thanks dirtyg, do you know where thats at?
Old 10-14-2009, 04:43 PM   #4
Send a message via MSN to CJ_Boxster
All the micro switches are located within the door itself, youll need a cross screwdriver, flat screw driver, 1 allen key for the allen bolt behind the plastic airbag cap, 1 torq screw driver for the 2 torq bolts on the armrest
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-14-2009, 09:32 PM   #5
Lewis:
If it behaves the same way whether you pull on the inner door handle or on the outer door handle, it's most likely NOT any one of the three microswitches. I would first suspect the window regulator itself (and very, very rarely the window motor).
Straightforward DIY, with the hardest part being the removal of the door panel. After you have removed the door panel a couple of times, it's a piece of cake.
Regards, Maurice.
schoir is online now   Reply With Quote
Old 10-15-2009, 05:12 AM   #6
Thanks Maurice. It seems to work when i pull on the inner handle and doesnt work when i pull on the outer handle?
