09-24-2009, 11:50 AM
#1
GAHH glass windowed top
Wondering if anyone has installed a GAHH glass windowed top on their 986 Boxster AND has an OEM rear speaker enclosure installed as well.
If so, is there any interference between the GAHH top and the enclosure at any point in the closing/opening cycle?
Also, if you have a rear and a side view photo of your GAHH glass windowed top installed on your 986 that you would be willing to allow me to use in a DIY guide that I am preparing, I would appreciate hearing from you.
Regards, Maurice.
09-24-2009, 02:43 PM
#2
www.klisstle.com
Hi Maurice,
I have a glass window GAHH on my 2000 986 and have the OEM rear speaker enclosure. No interference whatsoever.
I will see if I have any decent pictures. If so I will add them later today.
ddb
Feel free to use these if they're what you're looking for. If you need higher resolution versions let me know.
Reason: Add pictures
09-25-2009, 01:01 AM
#3
Real PITA to get to the engine with a GAHN top.  Glass doesn't fold.
09-25-2009, 06:22 AM
#4
Do you have the GAHH top installed on your Boxster?
09-25-2009, 09:43 AM
#5
Randall:
I originally installed an OEM canvas top with vinyl window, after stripping off my old top with slashed window.
I recently installed an '04 OEM glass windowed top complete with frame assembly, and in the process installed a used set of the new version transmissions and re-wired the electrics to the new set up.
The OEM glass top makes access to the engine compartment a little easier than the GAHH or Robbins glass tops.
Regards, Maurice.
09-25-2009, 08:03 AM
#6
Originally Posted by ddb
Hi Maurice,
ddb
That top is sharp; which version did you get? Sonnendeck? Canvas? I noticed they have multiple options: I'm purchasing one and getting it installed prior to the beginning of the rainy season and am not sure which material choice to go with...
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
09-25-2009, 01:46 PM
#7
www.klisstle.com
Thanks Oaktown! Back during 2005 when I ordered the top GAHH had two materials to choose from. I chose the higher quality material but don't remember what they called it.
I've seen their ad on the left side of this site advertising their new "Ultimate Boxster Top" with the frameless glass. If I ever have to buy a new one I will choose that one.
Best of luck,
ddb
12-30-2009, 08:31 AM
#8
Best of luck,
ddb
Finally bought the A5 glass GAHH top! Dropped at Metzel's in SF (referred by coworker who has an amazing new top on his E36 Bimmer) and labor charge is only $800.
Sawwwweeeeeeeeeeeeeeeeeet.
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
12-30-2009, 08:44 AM
#9
www.klisstle.com
Fantastic! Be sure to post some pictures when you get it back.
09-25-2009, 09:50 AM
#10
Hi Maurice,
ddb
ddb:
Thanks for the reply and for permission to use the photos.
If you have higher resolution photos, it would help to give GAHH a fair shot in a comparison with the OEM vinyl and the OEM glass windowed tops.
Regards, Maurice.
09-25-2009, 05:02 AM
#11
Hello, I have installed tons of GAHH tops with no complaints so far.
09-25-2009, 08:37 AM
#12
Hey Pete,
I'm down in Northern VA, any suggestions on where to get a new GAHH top?
Purchase and installed?
Thanks!
'02 Boxster Seal Grey or is it Gray?
-Alexandria, VA-
09-25-2009, 09:46 AM
#13
Originally Posted by BobMarley1
Hey Pete,
Thanks!
You can buy a GAHH top from the GAHH.com website.
For installation in NJ, you can visit Pete. For Northern VA ???
Regards, Maurice.
09-27-2009, 07:57 AM
#14
Hey Pete,
Thanks!
Take a ride up to Chatham. I have had customers drive down from Canada and as far south as Dulles Airport area.
09-28-2009, 06:10 AM
#15
Guest
A lot of people love the glass retrofit tops, just be aware that the older 3-bow tops were designed to have the plastic window fold in half. Since the glass can't fold, it is smaller in size so that it fits during retraction, but these tops also create a significantly reduced amount of topside engine access.
09-25-2009, 09:44 AM
#16
Peter:
Thank you for the information. Much appreciated from a pro such as yourself.
Regards, Maurice.
