Old 09-09-2009, 01:40 PM   #1
Convertible Top Problem
Went to put down the top today.I forgot to pull the opening lever before I presses the down button. Top will not go down---1997 boxter---I checked fuses d3 and b6 and both
check ok. ignition is on and handbreak is set. New owner , so your help will be appreciated. Indicator light on the instrument panel lights in the check mode.
PAULD is offline   Reply With Quote
