08-07-2009, 08:09 AM
Cam position sensor PO341
Ok ...got this code PO 341 on bank 1 and made the mistake of replacing the sensor to no avail and about $75.00 later. Can anyone give me some suggestions that do not involve expensive shop equipment? thanks in advance.
08-08-2009, 04:26 PM
Solid or flashing CEL?
How old is car? How many miles? When is the last time you did regular maintenance (how old are your spark plugs)?
If it was a solid CEL, I might just reset it and drive on. See if it comes back. It might be time to change your plugs and coils if they have 30K miles on them. The Boxster is the 1st car that I've owned that the spark plugs seem to actually matter. Suspect O2 sensor and MAF with every code.
But I don't know anything. Smarter folks here than me.
08-08-2009, 06:07 PM
Porsche "Purist"
You need to clear the code then turn the key on (without starting or touching the gas pedal) for about 90 seconds then turn the key off for at least 10 seconds.
This code can be caused by:
A loose connector at the sensor
Corrosion on the connector
Bad wiring from the sensor to the DME
Bad sensor
Bad DME
1987 924S. 2002 996TT. PST-2
08-08-2009, 06:09 PM
A bad connection
Bad sensor
Bad DME
paul, could the cam be the cause of this?
08-08-2009, 06:15 PM
Porsche "Purist"
p0011, 12, 13, 21, 22, 23 would indicate timing issues with the cams.
08-09-2009, 02:38 PM
Well I replaced the plugs and they did look crappy.
I cleaned the coils and switched bank 1 to bank 2
The code did not go off but I will shut it off and see what happens. If the problem switchs to bank 2 then i will know coil.
08-09-2009, 02:40 PM
Bad sensor
Bad DME
Paul sorry not clear on this. Is this how you shut off code or something you do after. If after please define purpose. Thanks is advance.
08-09-2009, 04:49 PM
Porsche "Purist"
You need to read and clear the code(s) using a Durametric or PST2. They do not clear themselves.
Once cleared you need to do the 90 second procedure so that the DME can relearn the base value of the sensors.
08-09-2009, 05:10 PM
great and thanks I will try
08-08-2009, 06:02 PM
one word...Honda.
Trying to find a cheap answer on a car of this caliber isn't going to be easy..you might find yourself chasing (and spending) more than if you just took it to a professional.
I'm hoping that your sensor is faulty - either that, or maybe your cam is actually triggering the fault...in which case...well, never mind
