Old 08-08-2009, 07:09 PM   #4
Fred Demara
Guest
Posts: n/a
Originally Posted by Paul
You need to clear the code then turn the key on (without starting or touching the gas pedal) for about 90 seconds then turn the key off for at least 10 seconds.
This code can be caused by:
A bad connection
Corrosion on the connector
Bad wiring from the sensor to the DME
Bad sensor
Bad DME
paul, could the cam be the cause of this?
