Old 04-20-2009, 07:07 PM   #1
Weird sound from under the dash
I have been having a strange sound coming from under my dash, and I was wonderng if someone out there has the same problem and/or can tell me how to fix it.
Ok I will try to describe this as best as I can.
Car on, but NOT running....turn your AC on. choose the upper vents, there is a sound of something under the dash...like a loover selector or somethng that electrically opens and closes to direct air flow.
Now choose heat or floor, you can hear the selector once again opening and closing.
Now here's my problem: Car is on, motor is on. radio off, AC off, Fan off.
Very quitely, I can hear somehting opening and closing, basically the same sound as described above.
It sounds like an electric motor trying to close the vents, and then resetting itself and trying again. Sounds like rocks rolling around in a muffled plastic box.
It has been doing this for years and I cant seem to pinpoint it.
Any ideas?
I dont know if this has anythig to do with it, but my radio does not tuen off when I take the key out. I have to push the button.
Gremlins I guess.....
2002 S
jhandy is offline   Reply With Quote
