Old 03-28-2009, 01:23 PM   #1
Allen K. Littlefield's Avatar
Question staggared wheel question.
My '02 has 17 x 7" up front and 17x8.5" in the rear. What would the consequences be if I also put 17x8.5" in front? The wheels would no longer be staggered so would this be a problem? Some of the 18" wheels have 8" in front and 10" in the rear so the stagger relationship is maintained. Any insight?
AKL
Old 03-28-2009, 01:37 PM   #2
This post would be better answered in a race forum. I know autocrossers like the wider wheels in front so the car has a better "bite" at turn in. Larger front wheels also add additional stress to the front suspension members, so I would think they would need to be strenghtend.
Look at Acura's approach to P1 this year in ALMS. They run the same width wheel/tire front and rear...they didn't last very long at Sebring due to hydraulic issues (probably the same with your car).
Probably not the best idea for a street driven car.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 03-28-2009, 05:39 PM   #3
Porsche "Purist"
Paul's Avatar
The tire sizes are more important than the wheel sizes.
1987 924S. 2002 996TT. PST-2
Old 03-28-2009, 08:21 PM   #4
Track rat
Topless's Avatar
Allen,
What do you want to accomplish? When I first got my car the PO had installed some fresh cheapie 205 tires all around. Grip was lousy and the car was prone to oversteer. I have since switched to 225/255 and the car is much more balanced and predictable.
Some experienced track drivers run the same tire and wheel size front and rear (245 or 285).
Pros
Higher ultimate grip, zero understeer, rear of the car rotates easily, can swap race tires front to rear for even wear.
Cons
Higher steering forces cause the power steering fluid to boil more easily. A P.S. cooler may be needed. Heavy steering in low speed turns. Car will oversteer easily, more prone to snap spin. Scary in the rain as hydroplaning is much more likely with 245s up front.
If you are chasing a title at the track it may make sense for you. For a street car/weekend warrior the benefits of running the same size wheels/tires may be limited.
Old 03-28-2009, 09:48 PM   #5
Lil bastard's Avatar
Typically, the wider the tire up front, the less it has a tendency for understeer.
The downside is that your low-speed manuevering (think parallel parking) requires 'Ahhhnold' type work on the steering wheel due to the increased rolling resistance.
Street cars typically have inherent undesteer for a reason.
A totally 'neutral' car will tax the skills of an ordinary driver.
You really have to work (all the time) to control a 'neutral' car, and if you don't... or can't, it'll get away from you with little warning.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
