Old 03-27-2009, 09:18 PM   #1
Alternator
Ok.. so I bought a optima R34 battery after thinking that i could not get my car started after it sat for a while. Plus the battery was 4 yrs old so i figured it was time for a new one. Well I started my car to warm it up and about 10 mins later I returned to the car to discover it had shut and that the A/C was still running but the engine was off. So now I have come to a cross road since it has to be the alternator and not the battery as i suspected it to be orginally .... So anyone have a DIY with pictures to replace the alternator. I bought a reman-bosch one but i need some tips on install....
clb0099 is offline   Reply With Quote
Old 03-27-2009, 11:10 PM   #2
Lil bastard's Avatar
Send me an IM w/ email and I'll send it to you.
But, first, make certain it is the alternator.
If you have a DMM, it's a simple check:
Battery: Remove at least 1 terminal and check for voltage across the terminals - s/b 13.0-13.2 Volts. A 12 volt battery is NEVER 12 volts if healthy. Each of the cells, wired in series, produces approx. 2.2 volts (X 6=13.2 volts)
Alternator: Reconnect terminals, start the car, turn on lights, Climate Control and stereo and check voltage across terminals (cables attached) - s/b 13.5-14.5 volts. This is your alternator output voltage.
If less than these values in either test, replace the indicated component.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-04-2009, 08:49 PM   #3
ok.. so i changed my alternator took only hr to do the whole job.My question is that when I read the output of my battery/alternator gave over 800 cold cranks when first started and was close to 13.5 volt. output. The battery is a red top R34. Does the output of volt. seem about right?
Old 04-04-2009, 11:23 PM   #4
Yes. The Bosche alternator output ranges from 13.5-14.5 volts. The battery alone s/b near 13.2 volts.
1976 BMW 2002
1990 BMW 325is
