Thread: Alternator
Old 03-27-2009, 11:10 PM   #2
Lil bastard
Lil bastard's Avatar
Send me an IM w/ email and I'll send it to you.
But, first, make certain it is the alternator.
If you have a DMM, it's a simple check:
Battery: Remove at least 1 terminal and check for voltage across the terminals - s/b 13.0-13.2 Volts. A 12 volt battery is NEVER 12 volts if healthy. Each of the cells, wired in series, produces approx. 2.2 volts (X 6=13.2 volts)
Alternator: Reconnect terminals, start the car, turn on lights, Climate Control and stereo and check voltage across terminals (cables attached) - s/b 13.5-14.5 volts. This is your alternator output voltage.
If less than these values in either test, replace the indicated component.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
