Old 03-04-2009, 10:37 AM   #3
I've had a lot of weird things go on at once so I don't know what caused what. Yesterday I reported that my top was vibrating. I put some WD-4 on the track and it seemed to fix it. When this happened, I already had the two flap things removed from each side to see if that was messing up the motion in anyway (which it wasn't). After spraying, I put the flaps back on and then the motor would go about 1mm every second in either direction. Then I was pretty mad thinking that it was completely broken. I tried starting my car since I hadn't done it in a while, and the battery was dead. Now I'm charging it up. Don't know if the battery had anything to do with the motor or vibrating (I say vibrating cuz the motor could have been weak) but hopefully when this baby is charged up, all this will be behind me.
Viper5 is offline   Reply With Quote
