Old 02-24-2009, 01:22 PM   #1
Thumbs up Mobil 1 Rebate
From the Cayman Club:
http://supply.mobil1.com/
$10 back with 5 Qt purchase. Limit 2/family.
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
Old 02-24-2009, 02:10 PM   #2
The glorious details
Click the "Get Rebate" button below to register and print the offer form now (available for a limited time only). Save the form for a future Mobil 1 purchase made between April 1 and August 31, 2009. Then, mail in your Mobil 1 proof of purchase with the offer form to receive your $10 rebate check.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 02-25-2009, 06:36 AM   #3
FTD
Excellent! Right about the time I will be due for an oil change.
Heads up: When creating an account, for first and last name, as well as street address I put 'private'. The rebate form now has my name and address as 'private', which won't work if they want to send me some $.
Don't do what I did.
Thanks for telling us about the rebate.
Old 02-25-2009, 09:28 AM   #4
I'm over due for mine. Thanks for the info!
S3adrag0n is offline   Reply With Quote
Old 02-25-2009, 10:57 AM   #5
Thanks for the info!!
dcporsche99 is offline   Reply With Quote
Old 02-25-2009, 12:09 PM   #6
Perfectlap's Avatar
don't mean to throw a bomb on the party but I'm going to stop using Mobil 1 and start using Castrol Syntec 5w-40 which is on Porsche's approved list. M1 was changed recently and I've heard it doesn't provide enough protection for both chain and bearing wear. Its obviously a controversial topic but if you search Pelican and Rennlist you'll see at least one engine rebuilder who will not guarantee a rebuild if M1 is used at all or zero weights.
Old 02-25-2009, 01:04 PM   #7
FTD
Sounds like good information. Why did you choose Castol other than the approval? Have you ever used Redline? It gets high ratings from the members here.
Old 02-25-2009, 01:22 PM   #8
Mobil1 is not longer 100% true synethic oil. Stay away.
Old 02-25-2009, 02:29 PM   #9
Keep the Mobil 1...I'm running Royal Purple 5W40.
Yes, this is a controversial topic, but I've read Charles Navarro and Jake Raby's comments and that's good enough for me.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 02-25-2009, 03:12 PM   #10
Schatten-Baum-Mechaniker
Where are you getting Royal Purple 5W40? at a FLAPS?
what price you paying?
thanks
Tommy
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 02-25-2009, 06:10 PM   #11
Does Royal Purple make a 0W40 and why did you go up to the 5W40? The 5W is for winter protection, right? Does 5W and 0W make a difference?
Jmatta,
Where in chicago-land did you pick up Royal Purple and how much per quart?
-Steve
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
Old 02-26-2009, 05:50 AM   #12
I usually get it from my Porsche tuner shop, but you can also get it through AutoZone (usually special order) or even Amazon these days. It will run you $9 to $10 or so a quart, but worth it (I change my oil once a year, less than 3000 miles).
I'd check with some of the high end european indy shops in your area; many of the indy's are RP dealers.
The recommended european formula is 5W40...I can't believe there's much difference between 0 and 5; I don't run it in winter anyway.
Check the online stores; lots of them carry it.
JGM
2002 Boxster S
Old 02-26-2009, 07:11 AM   #13
Brucelee's Avatar
To my knowlege, Red Line is the only Group V full syn you can buy today. That is why I use it.
Rich Belloff
Old 02-26-2009, 08:00 AM   #14
I use AMSOIL in my bike...got a bunch of Mobil 1 in the garage though so that will go first. Regardless, I cannot see why Mobil 1 cannot be used.
Bob Z. is offline   Reply With Quote
Old 02-27-2009, 10:48 AM   #15
Wow. Had no idea I would stir up all the discussion with a simple rebate link!
Anyway, I enjoyed the opinions expressed. Jmatta mentioned Charles Navarro and I just happened to be reading his oil treatise.
http://www.lnengineering.com/oil.html
I was reading the FAQs under "What viscosity should I use in my Porsche?" My brain is tired.
Mike
PCA since 1970
Old 02-27-2009, 12:53 PM   #16
This must be one of the hardest topics to discuss, but the info provided on LN's website is very informative. I've ordered 10 Quarts of Swepco 5w-30 due to it's ZDDP and Moly levels for my next oil change. However seeing the link to the PDF file "Oils ain't Oil" I'm really thinking of switching to Royal Purple instead. Thanks to the LN, Flat Six guys for sharing their expertice on a very complicated topic for us layman!
I'll probably still use the Swepco as for now though.
941MXVET is offline   Reply With Quote
Old 02-27-2009, 02:16 PM   #17
Hey 70Sixter...your post is very timely and it seems like all oil discussions go all over the place these days. This board is very informative and I think it's good to point out the good and bad and let indiviuals make their own decision.
As for opinions, you know what they say: "Like ************************************s, everybody has one"
JGM
2002 Boxster S
Old 03-04-2009, 10:17 AM   #18
Another oil post....
OK, so to add on to this thread a little late -
I've read through LN's and Jake Raby's site, and all of the posts I can find.
I see that Royal Purple 5W-30 appears to be a good choice, as well as Swepco. I see on LN's website that is Brad Penn is their recommended oil for aircooled P-cars, does the same apply for the water-cooled descendants?
I happen to have a local distributor for Brad Penn, although its a little more out of the way than the Royal Purple. Is anyone running the Brad Penn in their 986?
I'm an engineer by education, so when I saw I could do oil analysis and really get an idea of the oil composition, I was sold. Is there anyone currently doing it that could add any comments on composition trends to look for? i.e., my X content started to climb, and then I had to buy a new motor?
Thanks,
-Michael
'99 w/ 40K hoping to keep its original motor
machone is offline   Reply With Quote
Old 03-23-2009, 09:19 AM   #19
Bummer!! I just changed mine with M1 (10-30). The guy that I bought my Boxster from said that he had changed about 7k ago. Man, it was a good thing I did it (first time for me; I was a virgin!). It looked like he didn't even change the oil while he had the car (about 3 years with 10K; carfax report). The filter looked realy bad and the oil was a bit thick and syrup.
I'll just changed it early next time. By then, we'll have have our oil brand sorted out!
S3adrag0n
Old 03-23-2009, 09:42 AM   #20
Brucelee's Avatar
Porsche specs a 40 wght oil for this engine, not 10W-30. If it were me, I would change it now.
Rich Belloff
