Old 01-25-2009, 08:57 PM   #1
Send a message via MSN to CJ_Boxster
Originally Posted by ere9391
Yes, I'm getting fuel, air and spark. She is a 1998 boxster with 113k miles... Last week I was driving down the highway approx 65 mph. I then push down on gas to go faster and all of a sudden it started jerking and popping like I had bad gas or something....I had to pull on the shoulder of the highway because I lost all the power in the car. I tried to start it back, but it would just crank and crank, but not turn over an start......What do you think?
Try disconnecting the plug from the Mass Airflow Sensor then try and start the engine, if she starts right up, replace the sensor. Also try to rent the ODBII SCANNER from Autozone and check for pcodes n post them here and we'll help yah out
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 01-25-2009, 09:14 PM   #2
I had a 99' which did the same thing, cluncked out on my on I-5 in San Diego, 5 hours from home. It would turned over, but would not start, it was the MAF. $600 later, it was fixed by the dealer. Since then I've fixed my own MAF's under $250, a very easy to DIY.
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
Old 01-25-2009, 10:39 PM   #3
crank, but won't start
Okay, I just tried to unplug the mas sensor and start her, but she still did not crank over...I then rented a ODBII scanner and tested it. The codes I got are PO336 crankshaft sensor & PO727 engine speed sensor?
ere9391 is offline   Reply With Quote
Old 01-25-2009, 10:41 PM   #4
Old 01-26-2009, 06:41 AM   #5
Lil bastard's Avatar
Sounds like a mechanical timing issue to me.
Unfortunate for you if that is the case.
I wouldn't try to keep messing around cranking and turning it if I were you.
Get it to a dealer or a crack independent to find out what's really going on and hopefully that I'm wrong. good luck.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 01-26-2009, 07:51 AM   #6
The DME isn't receiving a signal from the crank sensor. Either the sensor has failed, there is a wiring issue or your DME has failed. Also could be possible the flywheel has lost a significant portion of its teeth but that is pretty unlikely.
To test the sensor, disconnect it at the motor and measure across pins 1 &2, it should have 0.8-1.0 kohm resistance at around room temperature (20 C). Across 1 &3 it should be open. If not the sensor is bad.
If the sensor is OK you need to test the wiring between it and the DME.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 01-26-2009, 03:34 PM   #7
Leave it to a "Master" to come with a logical conclusion. My friend's 3.2 DME 911 died a similar death; culprit was the crank sensor.
You learn a lot from these boards; not that I can remember it, but it's always a great resource.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
