Old 01-25-2009, 10:41 PM   #4
ere9391
crank, but won't start
Originally Posted by CJ_Boxster
Try disconnecting the plug from the Mass Airflow Sensor then try and start the engine, if she starts right up, replace the sensor. Also try to rent the ODBII SCANNER from Autozone and check for pcodes n post them here and we'll help yah out
Okay, I just tried to unplug the mas sensor and start her, but she still did not crank over...I then rented a ODBII scanner and tested it. The codes I got are PO336 crankshaft sensor & PO727 engine speed sensor
ere9391 is offline   Reply With Quote
