Old 11-19-2008, 04:03 PM   #1
ChrisZang's Avatar
run flat tires
Hi,
does anyone know if I can put run flat tires (I am thinking of Bridgestone Potenza 050 RFT) on my standard Turbo Twist (2002) rims?
Any disadvantages to run flat tires that anyone knows of?
I have dedicated track tires on a second set of rims, so I don't care so much about "handling under extreme conditions"
Old 11-22-2008, 10:28 AM   #2
husker boxster's Avatar
I can only hazard a guess on ques #1, but I'd think you'd be able to run them. The good folks at TireRack would be able to give you a definitive answer.
As far as ques #2, you will have reduced handling capabilities, a harsher ride, and possibly more noise with run-flats. The sidewall is stiffer than a conventional tire so it can handle the rigors of running with no air. A stiffer sidewall will create all the items I mention. Are the side effects worth it? I wouldn't think so, but that's JMHO. It's your car.
1989 928 S4 5 spd - black
Old 11-22-2008, 12:36 PM   #3
Track rat
Topless's Avatar
I drove a Z4 with Bridgestone run flats and thought they were awful. Felt like wagon wheels.
Old 11-22-2008, 12:59 PM   #4
x2 i had runflats on my vette and dumped them fast. very hard, rough ride.
Fletch
Fletch986 is offline   Reply With Quote
Old 11-22-2008, 03:09 PM   #5
While you can mount them no problem, they should only be mounted in conjunction with a tire pressure monitoring system. It is almost impossible to tell when a run flat is low on air, so unless you're going to check them each time you get in the car, it is wise to install such a system.
As to performance, you'll notice a much firmer ride. Personally, I wouldn't bother.
Boxster S
Old 11-22-2008, 04:19 PM   #6
Fletch
x3 - I have them on my wife's Lexus and can't wait to get rid of them - looks like less than 5K to go.
hard, noisy, rough ride, poor handling - other than that the are great
Old 11-22-2008, 04:43 PM   #7
ChrisZang's Avatar
thanks for all the responses and from preventing me in making a mistake
