Old 09-28-2008, 08:02 PM   #1
Question B&M short shifter: reverse is tough!
To those who have the B&M short shift kit, do you find it really harder to get into reverse?
I almost have zero feeling when I get into reverse, I kind of have to hope it's in...
Is this normal?
I also thought the shift action was a little too rough; I can't really flick my wrist to shift anymore...
Jacques79 is offline   Reply With Quote
Old 09-28-2008, 08:10 PM   #2
Porscheectomy
Is this normal?
Try adjusting the cable that moves when you move the lever from side-to-side. Reverse shouldn't be any harder to feel than the other gears, at least it wasn't in my case. Is this a 5 or 6-speed. If it's a 6-speed, it's very possible that if the cable isn't adjusted correctly, the lever can be hitting the base before the cable is moved adequately.
Required force definitely is higher with the B&M.
Old 09-28-2008, 08:25 PM   #3
Yeah I thought the B&M was the same thing as the Porsche OEM short shifter....I guess I was wrong because at my dealer they had a 2004 911 with an OEM short shift kit and the ****************s were much smoother and required less effort.
Old 09-28-2008, 09:40 PM   #4
B&M on prune juice....
23109VC is offline   Reply With Quote
Old 09-30-2008, 03:26 PM   #5
lmao
I missed that one
Old 10-01-2008, 06:39 AM   #6
You probably didn't get the cables back in properly. I have an '02S six speed and my B&M is nice, even a little notchy (which is how I like it). Compared to my 911 with a 915 tranny, this thing feels so precise and right I couldn't go back to the standard shifter.
Old 10-01-2008, 12:21 PM   #7
Agreed with the cable adjustment. Reverse is harder to get in on my shifter (porsche short shifter, but it really is just a b&m), but i know when its in.
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
