Old 09-28-2008, 07:10 PM   #2
blue2000s
Porscheectomy
Originally Posted by Jacques79
To those who have the B&M short shift kit, do you find it really harder to get into reverse?
I almost have zero feeling when I get into reverse, I kind of have to hope it's in...
Is this normal?
I also thought the shift action was a little too rough; I can't really flick my wrist to shift anymore...
Try adjusting the cable that moves when you move the lever from side-to-side. Reverse shouldn't be any harder to feel than the other gears, at least it wasn't in my case. Is this a 5 or 6-speed. If it's a 6-speed, it's very possible that if the cable isn't adjusted correctly, the lever can be hitting the base before the cable is moved adequately.
Required force definitely is higher with the B&M.
