Old 09-20-2008, 11:11 AM   #1
Squeaking Top
My car came back from the shop after a 17K service. It's been squeaking inside. Like styrofoam rubbing together. I eventually traced it to the rear top. Pressing the rear window I can replicate the squeak.
I searched for a cure but really found none. A lot of notes of squeaks but no fixes.
I checked my shop manual suspecting it was a tension issue. I opened the top a couple inches and looked at the mechanism inside hoping to find a way to reduce the tension. I suspect it was the rubber seal of the top squeaking aginst the edge of the rear deck lid when closed. Nothing that looked like an adjuster.
Finally, out of graphite I rubbed some original Armour All on all the rubber seals. It seems to have stopped the squeaking.
Anyone else have tis problem. If so, how did you fix it?
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
