				Squeaking Top
			My car came back from the shop after a 17K service.   It's been squeaking inside.  Like styrofoam rubbing together.  I eventually traced it to the rear top.  Pressing the rear window I can replicate the squeak.
 I searched for a cure but really found none.  A lot of notes of squeaks but no fixes.
 I checked my shop manual suspecting it was a tension issue.  I opened the top a couple inches and looked at the mechanism inside hoping to find a way to reduce the tension.  I suspect it was the rubber seal of the top squeaking aginst the edge of the rear deck lid when closed.  Nothing that looked like an adjuster.
 Finally, out of graphite I rubbed some original Armour All on all the rubber seals.  It seems to have stopped the squeaking.
 Anyone else have tis problem.  If so, how did you fix it?
				__________________'04 Black Boxster, 18" Carerra wheels
 "If you're not living on the edge, you're taking up too much space."
