Old 08-03-2008, 09:36 AM   #1
Aluminum lug nuts?
I'm putting studded 17mm rear wheel spacers on my 2003 S.
I've picked up aftermarket aluminum lug nuts from Pelican Part.I know that Porsche make magnisium lug nuts that will also work but they are more than twice the cost.
Has anyone experienced these aluminum lug nuts?
I'm concerned with galling and most importantly stripping and having a wheel come loose from aggressive cornering.
Thanks,
Jake
03 Boxster S
turbine guy is offline   Reply With Quote
Old 08-03-2008, 12:47 PM   #2
Just be sure to use anti-seize compound and torque them properly when you install them, and you'll be fine.
2000 Guards Red Boxster
There is no substitute.
Padawan is offline   Reply With Quote
Old 08-04-2008, 03:59 AM   #3
i share your concern. the factory steel pieces rust like h3ll; i bet the aluminum would fare a lot better from a corrosion standpoint. you can always etch them with alodine to prevent galling & pitting. use copious amounts of anti-sieze and be extra cautious about cross-threading.
insite
'99 Boxster
3.4L Conversion
Old 08-05-2008, 12:24 PM   #4
Not sure what kind of driving you are doing Jake, but most tech inspectors for racing will want steel lug nuts that show how many threads have engaged.
I would think aluminum would be stronger than magnesium.
I'm curious, are you also putting lugs up front or is it just for the 17mm spacers?
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
