Old 06-02-2008, 04:52 PM   #1
Question about low speed for radiator fans.
Now that I have my Boxster back from the shop (small fire from a failed power steering hose) and that part is all better I am back to my original quest. Although I don't overheat, I don't have low speed on either L or R fans. I replaced both resistors but that didn't do the trick.
Besides the odd chance that both relays have failed is there anywhere else I should look?
Hi speed does work fine as does when the AC is turned on.
Chris
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 06-02-2008, 10:16 PM   #2
Lil bastard's Avatar
Relays... !
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-03-2008, 06:18 PM   #3
I am ordering four new relays as they are cheap, but I swapped a couple around and there was no change. I still only had Hi-Speed. Hopefully replacing all the Relays does something. It is either that or the low speed really (to me) seems the same as the hi speed that comes one when you run the AC.
Chris
Old 06-03-2008, 09:42 PM   #4
well, there is no set point for the crossover from low to high speed on the cooling fans. This is determined by the DME using several parameters incl. coolant temp, ambient temp, driving condition, possibly even the sun sensor from the climate control.
It's easy to initiate high-speed because the AC causes this as a default, but low-speed isn't easy... maybe by pulling the high speed relays.
1976 BMW 2002
1990 BMW 325is
Old 06-03-2008, 11:42 PM   #5
If you can find someone with a PST2 you can test the fans, both high and low speeds.
Tool Pants is offline   Reply With Quote
Old 06-04-2008, 06:35 AM   #6
The jackals at the the indy porsche shop that has my car right now just called me to tell me that they found this same problem in my car, and said that it was a "minor" issue.
I asked how minor(clearly meaning how much to fix)? $250.
2001 Boxster
2014 Toyota Tundra
"Its Craptacular" - Bart Simpson 1997
joshua6060 is offline   Reply With Quote
