Old 05-13-2008, 12:12 PM   #1
Bose sound - am I going nuts?
Got in my Box on Saturday and the Bose system worked fine. On the return trip home (approx. 3 hours later) the Bose system LOOKS normal, flashes radio station, song title, etc...the problem is that NO sound came out? I hit the mute button several times thinking maybe I accidentally turned it on, but nope. Turned the car off, then back on, still no sound. Put a new CD in and the info flashed on the display but still NO sound.
Drove home. Car sat for an hour, came back to car to check fuses with husband, he starts the car and the stereo is blarring.
WTF?
This car is 3 weeks old to me (it's an O4 S) and has about 13,700 miles on it.
kennedi is offline   Reply With Quote
Old 05-13-2008, 12:53 PM   #2
Sorry I can't help...I think a stereo in a Porsche is totally unncessary; listen to the mechanical music and enjoy (of course, just my opinion). I yanked the stereo out of my 911 because it probably added five pounds with the speakers and such. Hope you find out what caused your problem!
Old 05-13-2008, 01:31 PM   #3
My bose radio did that one day a couple years back. It then came back on the next day and has been fine since. Very odd.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 05-13-2008, 01:54 PM   #4
bmussatti
Guest
Posts: n/a
I think your husband is just messing with ya. He does not want you driving the car.
Old 05-13-2008, 02:02 PM   #5
The Bose system in my 03 and has done the same thing a number of times. Restarting (rebooting) the car often does the trick, but if not I've found disconnecting the battery for five minutes works every time.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 05-13-2008, 05:16 PM   #6
Send a message via AIM to LoveBunny
I've never had that happen, but this is the only car I've ever had with a radio that will change a preset station to a completely different station if the signal is weak. 92.3 decides to change itself to 100.7 at any time it happens to feel like it.
LoveBunny is offline   Reply With Quote
Old 05-13-2008, 05:50 PM   #7
Jaxonalden's Avatar
If you don't mind my $.02 worth. You say the "Bose" system, unless all the system signals go through the amp in the front truck I don't think you can blame Bose. I'm sure some speakers are powered through the radio itself and if that's the case you problem is with the radio and not the Bose system.
I just checked my Bentley manual and the wiring diagram shows all wiring for the speakers, with the Bose system, run through the amp. So it's safe to assume that the amp is somehow overheating and tripping a thermal fuse. Once the fuse cools and resets the speakers are powered again.
Check to insure you don't have anything laying on or around the amp that might impede cooling air from circulating around it.
Old 05-14-2008, 05:13 AM   #8
Same problem has happened to me, came back after shutdown and restart.
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
pbanders is offline   Reply With Quote
Old 05-14-2008, 06:04 AM   #9
I hope you realize when you disconnect the battery for more than 5 minutes, you completely reset the ECU, it's settings and "readiness". Takes at least a week to remap once disconnected. I'd find another solution...
Old 05-14-2008, 07:56 AM   #10
I agree. The stereo in my Box sounds great but I very rarely listen to it. I prefer the sounds of the motor and exhuast system. I have been thinking about yanking my stereo out to save weight. The radio/CD, DSP, Speakers & rear speakers. Probably drop 15 pounds.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
Old 05-31-2009, 03:00 PM   #11
Porschephile
Tomikaze's Avatar
I've got this problem only mine has not fixed itself. Do I send out the amp to be checked?
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 06-01-2009, 04:23 AM   #12
I've had similar issues with my Bose system to....even on a cold night not that long ago. There is more to it than the amp sometimes overheating. It seems to be a common problem and nobody knows how to fix it.
Old 06-01-2009, 05:27 AM   #13
Porschephile
Tomikaze's Avatar
This guy does...
http://cgi.ebay.com/ebaymotors/986-PORSCHE-BOXSTER-BOSE-AMPLIFIER-REPAIR-SERVICE_W0QQitemZ180174689463QQcmdZViewItemQQptZCa r_Audio_Video?hash=item29f33f94b7&_trksid=p4506.m20.l1116
I'm sending mine out today and I will let you guys know the results...
Portland, Maine
Old 08-12-2011, 04:35 AM   #14
Bumping old thread. Anyone find a permanent fix or the problem to this yet? My car does this almost daily after the 2nd start up of the day.
ohhh my is offline   Reply With Quote
Old 08-12-2011, 05:27 AM   #15
I bought my 03 boxster about 2 months ago. Could not get the cd player to work. Tried everything it just would say loading and never get anywhere. I pulled out the manual on the radio and read it (didn't read anything that I wasn't already doing). Got in the car started it and the cd player worked like a charm and has worked ever since.... weird juju.. I know the porsche peeps are good but go figure you have to read a manual before it will operate; how did they ever figure that out??? lol
Wow, gotta stop reading the bad things on this forum. Wrote the above; took the car home for lunch coming back to work speakers go out !!! After arriving at work let the car sit for a minute then restarted and they came back on... sounds like amp getting overheated?
houstoer is offline   Reply With Quote
Old 08-31-2013, 06:06 AM   #16
Bringing an old topic back to life. I have a 987 and my Bose system is acting really weird. It started with audio fading from low to high volume. Now when I hit a bump on the road it turns on or off on it's own. When I turn it on I get nothing. When I hit a slight bump on the road the radio comes on automatically.
Anyone seen this issue before?
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
Old 08-31-2013, 10:51 AM   #17
batshapedheart's Avatar
I have the exact same issue, I'm sure its just loose cables needing resoldering at the least.
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
