Old 05-05-2008, 08:17 PM   #1
Question starting problems when tiptronic is in Park
Hello all:
i have a problem when starting my 99 boxster (62K miles) when tiptronic shifter is in park. if i set it in Neutral it starts. just recently changed my battery. will appreciate any help/suggestions. Thank you
redsteel is offline   Reply With Quote
Old 05-05-2008, 10:52 PM   #2
Lil bastard's Avatar
I had the same issue with my '99 Tip several years ago. Turned out to be a dirty transmission switch. Car was just out of warranty and so I hadn't started working on it much, I took it to the dealer and they cleaned and adjusted the switch while I waited - $67 - the only dealer service I've ever had.
BTW, at 67,000 mi., you're overdue for a tranny filter and fluid change (ZF, the manufacturer recommends every 45k mi.). It's an involved procedure for DIY, which I would rate experienced to advanced. If you had the dealer do that, they'd probably adjust/clean the switch for free, expect about $600 total.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 05-06-2008, 10:20 AM   #3
thank you!
thank you for the prompt reply to my qestion.
i have made an appointment with the dealership for tomorrow so that they clean the switch. regarding the tranny thay must have done it during the 60,000 dealership service... which i did some months ago. the tranny service should be a part of the 60000mile service, no?
will report tomorrow on that as well
