Old 03-19-2008, 11:52 AM   #1
Question Air Meter
I am trying to buy a 2000 Boxter. I had a pre-inspection done because when cold start it belches black smoke and runs rich and rough for about 30 sec's then smoothes out. I was told I need a new mas air meeter. That doesn't make sense because the roughness only lasts for a few seconds, but if I do need one there is two part #'s for these on for e-accelerator and one without. The moror is a 2.7 with tiptronic. Can anyone shed some light on this?
Thanks,
MR.G.
MR.G. is offline   Reply With Quote
Old 03-20-2008, 04:36 PM   #2
Thanks,
MR.G.
I don't know which one you would need, but have another option you might try. I just had a problem with mine and the shop that I took it to told me that I could try having them clean it. They said it works 50% to 60% of the time, especially if the problem isn't bad. My brother is a mechanic (non_Porsche) and said that he has a success rate of about 80 to 90% on vehicles as a whole. Having it cleaned cost me a little over $200 instead of much more to have it replaced. Hope that helps.
Robert
Robster is offline   Reply With Quote
Old 03-20-2008, 06:49 PM   #3
Lil bastard's Avatar
All the '00 and later cars are egas - no direct linkage between the accelerator and the throttle body - drive-by-wire. You need the one for egas cars.
The car doesn't have an Air/Fuel meter in the classic K-Jetronic sense. Instead, it uses a Mass Airflow Sensor in the intake plenum. The DME (computer) does the rest.
You can try to remove the MAF and clean it with a spray MAF cleaner. This works maybe 50% of the time. $200 for a MAF cleaning is VERY high, almost the cost of a new unit. This is a pretty easy DIY, you just need an anti-tamper Torx driver or bit. Takes maybe 45 min. max. Lots of How-To's here - use the search function.
It could be the MAF, but could also be a number of other things such as OČ sensors, Tiptronic fault, etc.
If you have an OBDII code reader, you could pull the codes and see if the car is throwing any minor ones that don't necessarily cause a MIL.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
