Old 02-25-2008, 02:38 PM   #1
Hey.... i topped of my car in 5th gear and it was fine.... there were no leaks either, so ill just check to see if its low. and if its not so its probably the master or slave cylinder right?
prsnmark6 is offline   Reply With Quote
Old 03-08-2008, 07:44 AM   #2
Clutch stuck
I had exactly the same problem on my 2001 Boxster. 8 weeks later the clutch would not move from the compressed position at all anymore. Had to have it towed to the dealership. $700 repair.
Turned out a spring was broken and the cylinders just fine. Therefore I would have that fixed soon.
miles is offline   Reply With Quote
