02-12-2008, 05:14 PM
#1
Frustration with Aristocrat Motors in Kansas City
So, a little background: Last week I managed to hit some debris on the highway at night, which managed to scrape up and crack my GT3 bumper, chunk a wheel, and throw the alignment way out. I threw my other wheels on the car after, which were just road force balanced 100 miles ago.
So, I drop it off for an alignment yesterday. I also ask them to check my interior door handle microswitch, as the driver door stopped lowering from the inside a few weeks ago (works fine from the outside, and lowers properly when door is open or you activate the top). The service writer calls me a few hours later to tell me the alignment was quite off, but nothing is damaged. He also mentions that my driver door needs a new regulator. I ask why I'm feeling vibration at speed if nothing was bent or damaged, and he says "well you have a bent front wheel," to which I responded "those were just road force balanced and were true, I haven't even hit a bump in the car since, but can you give me the runout numbers on the damaged wheel?" He tells me that he "can't do that" but that you can "see that its bent by looking at it" (which would have to be a pretty sizable warp to be visually seen). So, I'm going to have the tire shop re-spin these on the Hunter this week.
I drive away from the dealer, and first thing I notice is my stereo sounds horrible (to those who don't know, my car has a pretty ridiculous audiophile system installed) and that my GPS nav head unit has been switched from "CD" to "FM" (which takes several executed keystrokes on the touchscreen, not like bumping a button by accident) and then on the drive home I notice the alignment is still off (and the steering wheel is off center) and that I still have vibration.
I call him first thing in the morning to explain these problems (I figured while they had the door apart to inspect the window system they didn't plug something back in right). He tells me that the tech didn't have the door apart at all, so he can't imagine what could have happened. I run the car over to an audio shop here, and we dig around this and that and it turns out someone swapped the left and right inputs on one of the power amps (which are located in the front trunk) and then all is well again.
So, this brings me to two things: First, as far as I can tell, they have no reason whatsoever to be playing in the front trunk while doing an alignment, maybe to access the strut tops from behind the front trunk, but not in the front trunk. Secondly, how exactly does one diagnose a window regulator without taking the door apart?
All in all, I'm considerably less than pleased by the experience, which I made very clear to the service writer today. We'll see how they want to handle this.
Patrick
02-12-2008, 05:59 PM
#2
Guest
Patrick, sorry to hear about your bad experience. But really, your first clue to-steer-clear should have been the name of the dealership! Who in their right mind names something "Aristocrat".
02-12-2008, 07:04 PM
#3
Detective Jeph is on the case!
Perhaps while replacing the window regulator, the battery was disconnected? That justifies entry into the front trunk. Could that also reset some of your stereo settings? Or will cutting of the power leave it exactly how it was? I don't know.
And this may be a stretch, but perhaps while removing the battery cover or something the wires were unplugged some how on the amp -and when reconnected were swapped.
Just a possibility...
(Now I want to see what your trunk looks like to see if I can get to the bottom of this. Post a pic if you're REALLY bored.)
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
02-12-2008, 09:49 PM
#4
I agree on the name, but like most cities, they're the only show in town, and the guy from my insurance company wanted it done at the dealer (still not sure why on that, if anything, that just costs them more money).
Anyway, with regard to the electrical things, I'll post a pic tomorrow when I get a bored moment, but, let me explain that a) they did not replace the regulator, as I wouldn't let them without showing me documentation of testing to determine that it is, indeed, the culprit (correct me if I'm wrong, but there is no way you could determine if the regulator was bad without taking the door apart- and also, since the window works properly from the outside door handle, when the door is open, just not from the interior handle- leads me to suspect the interior switch) and, b) they did not disconnect the battery, as the head unit would have been in suspend mode and require a DVD to re-set itself. It took deliberate action to go "menu," "source select," "FM," and then tune a station is. There was no reason whatsoever for them to be playing with the audio hardware (its all in the front trunk, basically where the spare tire would be, i.e. nowhere near anything mechanical like suspension bits), and for Christ sake, if you absolutely have to go unplugging things, either make sure you label things so you can put it back together properly, or CALL ME and ASK!
Think I'm going to have a nice long talk with management tomorrow....
Patrick
02-13-2008, 07:27 AM
#5
There are a lot of good independent shops in the area, typically I would avoid the dealer unless it is warranty work. Your insurance company has no right to tell you where to get your car repaired.
Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
02-13-2008, 05:04 PM
#6
I agree with Todd. There are plenty of shops, I would take it to IA.
03-07-2008, 03:38 PM
#7
All sounds crazy. Not sure who to trust. I've had my Boxster for about nine months and had a couple of things done at BHR downtown. So far I'm happy with the work they've done for me (axle boots, ignition switch). Good Luck.
00 Boxster S
72 911T
99 A6 Avant quattro
03-07-2008, 04:23 PM
#8
Crazy and not sure who to trust is right. "Frustrating" comes to mind as well. I have just recently heard of DAS, who is BHR?
Related to this mess, the creaking/ squeaking I'm hearing only becomes an issue after the car has been driven 20 min or so, which typically involves highway driving. Any thoughts anyone?
Patrick
03-07-2008, 04:50 PM
#9
BHR = Bob Hinson Racing. They are on Gillham Rd (I think). Its been a while since I was there and I forgot about them. It's a shop you should check out. They've been around a long time.
79 911SC Targa.. gone but not forgotten
2001 Boxster Black/Savanah Beige
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
I'll never own another black car!
03-08-2008, 08:19 AM
#10
Bob Hindson Racing. About 27th and Holmes, original location.
http://www.bobhindsonracinginc.com/SiteResources/Data/Templates/templatea.asp?docid=514&DocName=Home
Orginally started by Bob Hindson around 72-73. He was Art Bunker's race boss and raced factory 914-6s along with Kendall Noah back in the early 70s.
The shop is now owned by Aaron Holstrom. Aaron worked for BHR since he graduated from high school—a while ago. Good guy. I'm having them weld new rear sway bar mounts on my 911 next week.
I was going to have Aristocrat change the oil on my Boxster since they do it for about $60 including oil and filter, but now I'm not so sure. Probably should do it myself.
00 Boxster S
72 911T
99 A6 Avant quattro
03-08-2008, 02:48 PM
#11
Thanks for the help guys, I am going to pay BHR a visit. I live downtown, so their location would be very convenient. It took a bit of refreshing, but I do know who Bob Hinson is. I hope Aaron has the same good business sense.
As far as Aristocrat changing your oil, I've noticed the $60 price, but after the fiasco I've had with them, they're never seeing my car again. I think I forgot to mention in the previous posts that the problem pertaining to my audio turned out to be cross wires on one of the power amps. Only cost me $300 in diagnostic time by the audio shop to figure that out, and furthermore, Aristocrat had no reason whatsoever to be unplugging leads from a power amp while doing an alignment! I also have two calls in each to both the service manager and the president of the company- no call back from either of them. Not exactly a company I want to do business with.
Patrick
| Thread Tools |
| Display Modes |
Hybrid Mode
