Old 12-30-2007, 11:40 AM   #1
Battery disconnected with left door opened and window fully raised
Good afternoon to everybody
First able HAPPY NEW YEAR to all the Porsche fanatics......
I have a problem with my Boxster...I was replacing my climate control unit.....
I had disconnected the battery first...but my left door was opened and the window fully closed !!!!!!!!!!
Now when I reconnect the battery...I cannot lower the window to close the door...
Nothing works.......Anybody knows how I can reinitialise the alarm /car, please?
Thanks so much
michel
naelec is offline   Reply With Quote
Old 12-30-2007, 04:14 PM   #2
Porsche "Purist"
Paul's Avatar
Have you tried using the key to unlock and lock the doors?
Have you checked your fuses?
1987 924S. 2002 996TT. PST-2
Old 12-30-2007, 05:47 PM   #3
After the battery has been disconnected you need to run the windows all the way up and down a few times.
Tool Pants is offline   Reply With Quote
Old 12-30-2007, 06:05 PM   #4
when my battery died I opened my door and then couldnt close it because of the window being up. What you have to do is this, in your fuse box there is a yellow fuse pull it out connect your jumper to it positive then ground on the door hinge and that will give you the current you need to pull it down a bit. This is assuming you have no current, if you do and your window is not moving then it is prob definitly the fuse.
Porsche_farsi is offline   Reply With Quote
