Old 11-15-2007, 08:32 PM   #1
Unhappy Power Steering Leak???
If Someone Has Encountered This Problem, Please Help!my 02'boxster Had Serious Leak So I Took It To A Mechanic And He Replaced The Power Steering Pump And Reservoir,however When He Replaced It The Car Was On For A Few Minutes And Then It Started Making A Weird Noise And It Caused A Piece From The Reservoir That Goes Connected To The Pump Its Like ( A Seal) To Melt And It Started To Leak All The Power Steering Fluid Out. I Purchased Another One And It Happened Again!what Should I Do??
Is This Issue Related To The Rack And Pinion??
JESSENERICA is offline   Reply With Quote
Old 11-16-2007, 04:28 AM   #2
We could use a little more info on your problem -- where exactly is the leak, at the pump or at the front of the car?
Did you have noise or hard steering before the leak?
What mechanic has worked on your car - dealer, Porsche specialty independent, or other type?
Did they show you the failed seal -- is it red plastic or black rubber?
There are several seals on the pump and there are 2 reservoirs.
Heat causes the red plastic clamp/seal to melt and leak.
But, high pressure from a failed rack and pinion unit could blowout other seals on the connecting pipes and/or the pump.
Since heat doesn't seem to be the cause then the rack and pinion unit or a valve may be the real cause.
There are few people that have had rack failures, and they may have better info for you. I have only delt with the red plastic clip failure.
Sboxin is offline   Reply With Quote
Old 11-16-2007, 10:33 AM   #3
Did you track the car hard between the first and second melting of the red piece? Usually it melts due to return line heat from tracking the car really hard...
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 11-17-2007, 06:37 PM   #4
Porsche "Purist"
Paul's Avatar
What was used to refill the system?
1987 924S. 2002 996TT. PST-2
Old 11-18-2007, 05:38 AM   #5
husker boxster's Avatar
Good question and the reason Paul asks is because Porsches do not use garden variety power steering fluid. Porsche recommends Pentosin CHF 11S fluid. Regular ps fluid and Pentosin do not mix.
Better ask you mechanic what he used.
1989 928 S4 5 spd - black
Old 11-18-2007, 06:06 AM   #6
Porsche "Purist"
Paul's Avatar
Yes regular PS fluid will turn rubber seals into goo.
Old 11-18-2007, 06:10 AM   #7
It sounds like the tech didn't remove the blanking plugs from the new pump when he installed it so no fluid was getting into the pump and it burnt out. There is a cheap P/S fluid thats mixable with 11S but I can't remember the Pentosen(sp?) number.
wvicary is offline   Reply With Quote
