Old 10-31-2007, 06:28 AM   #1
There Is No Substitute.
rick3000's Avatar
I just dropped mine in, and ended up ruining one of the bolts. It is probably the stupidest thing I have ever done.
Once you drop them in, twist them until they sit flush with the metal.
Old 10-31-2007, 08:19 AM   #2
The ones currently on my car has only 1 indentation (facing rear). But locking at the bolt on the hardtop, it looks like there should be 2 (1 facing rear and 1 facing front) like the photo posted by Tool Pants. Anyone know why? Do I have the wrong spin locks?
02' Seal Grey Mettalic Boxster
www.victoreric.com
victoreric is offline   Reply With Quote
Old 10-31-2007, 09:49 AM   #3
Maybe you should post a pic of your spinlock. The recess is not visible in this picture but it is where the bolt is. The recess is there so the bolt can slide easily. If you reverse it you are not going to be able to tighten it properly and will probably end p stripping it out. (see above post)
http://boxster.wikia.com/wiki/Image:Spinlock-1.jpg
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 10-31-2007, 02:24 PM   #4
Here's a photo of mine.
In comparison, it looks like mine isn't installed. (I'm 2nd owner so don't really know if it was ever installed)
Can anyone tell me if it's on there?
www.victoreric.com
Old 10-31-2007, 02:34 PM   #5
You do not have one installed. When you get them, they are marked L or R so that you should not have difficulty determining which goes to which side.
John
szentej is offline   Reply With Quote
Old 10-31-2007, 02:35 PM   #6
You don't have them, just an empty hole. Usually there is a plastic plug in the hole if you do not have them, but the plug likes to fly out.
This is what they look like before you put them in. You should read the renntech article.
Tool Pants is offline   Reply With Quote
Old 10-31-2007, 07:33 PM   #7
rick3000's Avatar
If you look at your picture and the picture tool pants posted, you will notice the little indentation. That makes sure the spinlock is in properly and sitting flush.
Old 11-01-2007, 08:04 AM   #8
Thanks guys.
www.victoreric.com
