Old 09-23-2007, 12:20 PM   #1
How to Replace Gear Shift Knob and Boot?
I have tried searching but no luck. Maybe Im not doing it right
Bought myself a Tequipment shift knob and boot, just need to find out how to remove the old one and install the new one.
Thanks fellows.
panameras is offline   Reply With Quote
Old 09-23-2007, 01:04 PM   #2
bmussatti
Guest
Posts: n/a
Here ya go mate!:
http://www.986forum.com/forums/showthread.php?t=11547&highlight=remove+knob
Old 09-23-2007, 08:11 PM   #3
I should mention mine is 6 speed manual. I think that thread was about Tiptronic but thanks anyway.
Old 09-23-2007, 08:33 PM   #4
Franco's Avatar
Hi, I have a 986 and to remove the boot you must wiggle it a little and pull it out , it is only holding with 6 plastic clips that are part of the plate holding the leather in place.
Then check if there is a screw holding the knob in place , mine was only press fitted over the shift pin, loosen the screw if any and then pull on the knob like you want to brake it off and you are done my friend.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
Old 09-23-2007, 09:10 PM   #5
Perfectlap's Avatar
pry off the sides of the orginal boot with your hands pulling up on the edges.
lower the top.
remove your shoes.
facing the windshield, place one foot on each seat
place one hand on the windshield header and the other on the old shift knob.
Pull straight up on the shift knob and will come right off.
The leverage of standing over the shift knob makes it very easy to pull off.
slip the new knob on the lever, tighten the allen screw on the collar and snap down the boot.
BORN: March 2000 - FINLAND
Old 09-25-2007, 12:53 PM   #6
Ah thanks guys. That "standing on seats and pull" solution sounded brutal but worked very nicely
Old 02-12-2014, 09:13 AM   #7
xxxx,faster,xxxxxxx
remove shift knob 6 speed press fit
For those press fit knobs that absolutely will not pull off. I tried it all to no avail. I had to find another way to get it off. Since I had a new one, I could afford to trash the old one. I removed the plaque on top(popped it off). I then took a box cutter and cut the leather boot cover at backside until it came off. Then took a box cutter and sliced from top to bottom the shifter until it peeled off. Cuts easy. Very quick.
benstaples is offline   Reply With Quote
Old 02-12-2014, 04:28 PM   #8
Standing up works...never pull on the knob with your face in target range...best way to knock out a bunch of teeth when it lets go; just keep the family jewels out of the way.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 07-09-2022, 07:06 PM   #9
Ask him how he knows? HaHa.
I just read this post and got "in the position" and it pulled off without too much effort.
When I previously tried to pull up from the side, with what seemed like a lot of force, it did not budge. The pulling straight up is the secret.
Thank you everyone for this useful info. Full set of teeth and jewels intact
DreamSign is offline   Reply With Quote
