Old 09-23-2007, 08:33 PM   #4
Franco
Franco's Avatar
Hi, I have a 986 and to remove the boot you must wiggle it a little and pull it out , it is only holding with 6 plastic clips that are part of the plate holding the leather in place.
Then check if there is a screw holding the knob in place , mine was only press fitted over the shift pin, loosen the screw if any and then pull on the knob like you want to brake it off and you are done my friend.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
